Wed, Jan 15, 4:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Subject: How to disable animate on all XYZ transitions and rotations
Uncanny_Film ( ) posted Tue, 13 August 2024 at 5:58 PM · edited Wed, 15 January 2025 at 4:46 AM
Hello,
I would like to know how to quickly disable each dial or all dials from setting a keyframe.
You can only do this by going into the properties of each dial and un-checking animated.
This gets extremely tedious if you have multiple objects. Is there a way to mass do this. To disable all dials from animating or Adding a keyframe.
Thanks,
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
primorge ( ) posted Wed, 14 August 2024 at 10:40 AM · edited Wed, 14 August 2024 at 10:40 AM
Maybe with Python.
Otherwise, no way that I know of. Creating a New Master and toggling animatable in settings will record some change in the dependency listing, though no change will act in the dialed dependency... So not possible to connect settings options to a dependency.
Certain properties such as Visible and Joint Editor settings such as centers and orientation of a joint can be keyed animatable and attached to a dependency, other than that...?
I did however see something strange in ShaneNewville's post about using magnets in your other thread, a few parameters in the Other parm group that are curious. Then again I don't use magnets very often and am only a novice Poser animator, might be relevant, might not...
Y-Phil ( ) posted Thu, 15 August 2024 at 7:58 AM
I may be wrong but using Python I have found a way to get the Min/Max values, and to set them, but there wasn't any function to access the Animated boolean. One that's available is through the list of inputs of each node of each material, but I doubt that it's related in any way.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
ShaneNewville ( ) posted Fri, 16 August 2024 at 3:36 AM
primorge posted at 10:40 AM Wed, 14 August 2024 - #4488376
Those Mag dials affect how much influence each magnet has over it.  They automatically appear on anything that has been added to a magnet.
_____________________________
My most recent Poser animation:
Previs Dummies 2
