Sat, Dec 21, 9:59 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 17 11:57 am)
banner
Subject: forum blMilMan_m4b
romangirl ( ) posted Tue, 20 August 2024 at 10:59 AM · edited Sat, 21 December 2024 at 9:55 PM
Help!  Can't do  any thing!  Yesterday, I created a great (to me)  M4 character and happily turned off my Poser 11 program. Today, I tried to pull a  Michael 4 and/or Victoria character from the pose room or library and was asked to find blMilMan_m4b.  I found it, but didn't know what to do.  I'm dead in the water!
bdpoppa ( ) posted Tue, 20 August 2024 at 2:44 PM
Find it using the search screen that comes up looking for it.  Then just highlight it and click on select in the bottom right corner.
RodS ( ) posted Tue, 20 August 2024 at 2:52 PM · edited Tue, 20 August 2024 at 2:55 PM
Hi, Sue!
I'll see if I can help a bit. That blMilMan_m4b it's looking for is actually an .obj file for M4's actual body (blMilMan_m4b.obj).
I have Poser File Editor, and took a look at where that file it's looking for lives. The first line in that CR2 file is: figureResFile ":Runtime:Geometries:DAZPeople:blMilMan_m4b.obj" This line appears twice in the CR2 file.
The .obj file path is: DAZ PEOPLE / Runtime / Geometries DAZ People.
Sounds like you may have some file corruption going on, since you cannot get V4 to open either. I'm assuming you still have the original installation files. A fresh installation should restore those files. And be sure to back up everything if you can.
I hope this helps a bit. Let me know.. You might try bdpoppa's suggestion first - when the error notice pops up. If it works, no reinstall is needed.
"I reject your reality and substitute my own" - Adam Savage
romangirl ( ) posted Wed, 21 August 2024 at 11:03 AM
Struggling, guys.  Thanks!
romangirl ( ) posted Thu, 22 August 2024 at 1:44 PM
I don't know how this happened, or if I'll ever be able to fix it, but for now,
I'll have to say
I'LL BE BACKKK!
romangirl ( ) posted Thu, 22 August 2024 at 2:07 PM · edited Thu, 22 August 2024 at 2:08 PM
I'll have to say
I'LL BE BACKKK!
By the way, I used to work with Poser 9. When FLASH disappeared, it took with it my library. Next, I got Poser 11, which I've been using ever sense. But now all my characters are gone in the Poser 11 library . Just now, I opened Poser 7, and was able to open characters from the library. But P7 is painfully slow, and lacks the features held by P11.
If I have to, I will have go back to P7. Once again, I'LL BE BACKKK!
Thanks again!
hborre ( ) posted Thu, 22 August 2024 at 2:59 PM
Online Now!
Libraries typically do not vanish unless there is a complete software reinstallation, unintended runtime deletions, or hardware corruption, which may suggest a more serious issue. By searching the computer's hard drive, you might locate your missing content, allowing you to re-establish the connection of the runtime folders to the P11 Library.
romangirl ( ) posted Fri, 23 August 2024 at 11:15 AM
Thanks!
romangirl ( ) posted Fri, 23 August 2024 at 12:02 PM
I'm backkk!  I found my lost P7 library!  I have always used the P7 library even when working with P11.  I had this problem once before, but forgot.   I clicked on "add another library" and my characters returned.  Thanks all!
