Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 16 2:29 pm)
Hi, Sue!
I'll see if I can help a bit. That blMilMan_m4b it's looking for is actually an .obj file for M4's actual body (blMilMan_m4b.obj).
I have Poser File Editor, and took a look at where that file it's looking for lives. The first line in that CR2 file is: figureResFile ":Runtime:Geometries:DAZPeople:blMilMan_m4b.obj" This line appears twice in the CR2 file.
The .obj file path is: DAZ PEOPLE / Runtime / Geometries DAZ People.
Sounds like you may have some file corruption going on, since you cannot get V4 to open either. I'm assuming you still have the original installation files. A fresh installation should restore those files. And be sure to back up everything if you can.
I hope this helps a bit. Let me know.. You might try bdpoppa's suggestion first - when the error notice pops up. If it works, no reinstall is needed.
"I reject your reality and substitute my own" - Adam Savage
I don't know how this happened, or if I'll ever be able to fix it, but for now,
I'll have to say
I'LL BE BACKKK!
By the way, I used to work with Poser 9. When FLASH disappeared, it took with it my library. Next, I got Poser 11, which I've been using ever sense. But now all my characters are gone in the Poser 11 library . Just now, I opened Poser 7, and was able to open characters from the library. But P7 is painfully slow, and lacks the features held by P11.
If I have to, I will have go back to P7. Once again, I'LL BE BACKKK!
Thanks again!
Libraries typically do not vanish unless there is a complete software reinstallation, unintended runtime deletions, or hardware corruption, which may suggest a more serious issue. By searching the computer's hard drive, you might locate your missing content, allowing you to re-establish the connection of the runtime folders to the P11 Library.
Help! Can't do any thing! Yesterday, I created a great (to me) M4 character and happily turned off my Poser 11 program. Today, I tried to pull a Michael 4 and/or Victoria character from the pose room or library and was asked to find blMilMan_m4b. I found it, but didn't know what to do. I'm dead in the water!
