New Poser Users Help F.A.Q (Last Updated: 2024 Sep 28 9:00 am)
Are they showing in the preview?
I'm assuming they aren't set as invisible.
First one is a preview. Second is a render that also showed same view in preview I did not set them as invisible
hb I did not keep track of the slightly panicky settings I changed but the last that works fine is one I’ve used previously as were the ones that went bad. I don’t expect any solution this with limited info. If it ever happens again God forbid. I’ll keep better track. 🤠
First, when you load the scene, did you get a message asking you to locate anything? It might be a problem with Poser not finding the geometry for the figures.
Otherwise, check the visibility for the items either by body part.
or by body
It's also possible that the scene was corrupted. If that's the case, since this isn't the first scene that got corrupted, you might want to have your hard drive checked. It might be failing. When my drive was failing, I had a lot of corrupted scenes.
The very best low-level analysis tool I've ever used was Spinrite. At the time, we were using it by booting on a floppy disk, but I suppose that it should be possible to put this on an USB stick. And it has received a major update recently, in order to handle correctly the most recent technology.
https://www.grc.com/sr/spinrite.htm
More infos on Youtube:
https://www.youtube.com/watch?v=Lcoa43spYRk
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Spinrite is not OS dependant, the only difficulty being in accessing the OS disk, even plugged in a standard PC. But sure enough, that won't be easy, if doable, with a Mac computer...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
both in preview and later in a render, important parts of the actors disappeared. I quit Poser and rebooted and started Poser and found the same problem. I changed the rendering components (cannot remember how many times) but then the problem appears to be "fixed" Hmm?
drawn
