Mon, Jan 20, 10:03 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 20 7:56 am)
Subject: Setting up the physical surface root node
RedPhantom ( ) posted Sat, 19 October 2024 at 6:08 PM · edited Mon, 20 January 2025 at 10:01 AM
Site Admin
I'm trying to learn to use the physical surface node. When I render, the colors look washed out. Here's a render with the poser root node
And here it is with the physical surface
Here's my material setup.
What's causing the color change?
Sunfire ( ) posted Sat, 19 October 2024 at 6:39 PM
Try making the color white instead of that pale grey.
Also make sure the normal map, displacement map, and roughness map all have their gamma set to 1.
Sunfire's Creations
RedPhantom ( ) posted Sat, 19 October 2024 at 6:54 PM
Site Admin
It's a little better but the black still looks washed out.
Sunfire ( ) posted Sat, 19 October 2024 at 9:18 PM
What lights are you using?
Sunfire's Creations
RedPhantom ( ) posted Sat, 19 October 2024 at 10:05 PM
Site Admin
There's 1 point light at 40% and an hdri of that hideous room in the background
Sunfire ( ) posted Sat, 19 October 2024 at 10:25 PM
The thing about the physical root is that it is PBR, works best with Superfly, which also means it will react to the light and what's around it.
Sunfire's Creations
Varnayrah ( ) posted Sun, 20 October 2024 at 7:36 AM
Online Now!
To be honest I like the physical surface render much more, the other looks more flat.
RedPhantom ( ) posted Sun, 20 October 2024 at 8:05 AM
Site Admin
Varnayrah posted at 7:36 AM Sun, 20 October 2024 - #4490564
I think so too. I just wanted the colors to show more
RedPhantom ( ) posted Sun, 20 October 2024 at 8:08 AM
Site Admin
I am using Superfly. I tried using different light setups. The only time I got a good black was when I had no lights but that didn't work for the rest of the scene. I tried that to make sure I wasn't getting any glowing.
VedaDalsette ( ) posted Sun, 20 October 2024 at 10:02 AM
Darken the physical root specular.
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Kalypso ( ) posted Sun, 20 October 2024 at 12:38 PM
Site Admin
You can also try changing the Texture strength of your diffuse map to 1.1 and if that's too much start with small increments.
ChromeStar ( ) posted Sun, 20 October 2024 at 2:54 PM
VedaDalsette posted at 10:02 AM Sun, 20 October 2024 - #4490572
I'm also thinking the lightening has to be coming from specularity. You could lower it for the whole garment or use the typical PoserSurface cheat and plug the color texture map into the specular input too.
RedPhantom ( ) posted Sun, 20 October 2024 at 3:11 PM · edited Sun, 20 October 2024 at 3:12 PM
Site Admin
Darkening the specular seems to help.
I can now do the rest of the outfit and he can be properly dressed.
Thanks so much to everyone
