(Last Updated: 2025 Jan 31 1:07 am)
Try making the color white instead of that pale grey.
Also make sure the normal map, displacement map, and roughness map all have their gamma set to 1.
It's a little better but the black still looks washed out.
There's 1 point light at 40% and an hdri of that hideous room in the background
The thing about the physical root is that it is PBR, works best with Superfly, which also means it will react to the light and what's around it.
I think so too. I just wanted the colors to show moreTo be honest I like the physical surface render much more, the other looks more flat.
I am using Superfly. I tried using different light setups. The only time I got a good black was when I had no lights but that didn't work for the rest of the scene. I tried that to make sure I wasn't getting any glowing.
I'm also thinking the lightening has to be coming from specularity. You could lower it for the whole garment or use the typical PoserSurface cheat and plug the color texture map into the specular input too.Darken the physical root specular.
Darkening the specular seems to help.
I can now do the rest of the outfit and he can be properly dressed.
Thanks so much to everyone
I'm trying to learn to use the physical surface node. When I render, the colors look washed out. Here's a render with the poser root node
And here it is with the physical surface
Here's my material setup.
What's causing the color change?
