Sat, Feb 1, 1:36 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 31 3:19 pm)
Subject: camera shortcuts?
Jin_Yindao ( ) posted Sat, 21 December 2024 at 4:04 PM · edited Sat, 01 February 2025 at 12:44 AM
I cannot find the keyboard or mouse shortcuts for panning the camera.  Can someone tell me what they are?  I have all the rest set.
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
Richard60 ( ) posted Sat, 21 December 2024 at 7:50 PM
There are no keyboard shortcuts.  If you go to Edit-->General Preferences-->Interface there you will find all the possible things to assign a keyboard key to activate the command.  There are no camera movements listed. You can select a particular camera, but not control the movement of that camera via the keyboard.  You can use the mouse on either the Camera Control ball in that window OR use the mini ball in the upper right corner of the Poser window.  Either of those will move the current camera view around.  The most likely reason there are no keyboard shortcuts is that the Current View Camera and the camera selected via the Parameters control panel are not the same.  You can have the View camera set to Top (looking down on the scene) and have the main camera selected in the parameters palette and the controls will move the Main Camera which you can watch from the Top View to put it where you want.  So unless you select both the View camera and the Parameters for that camera then the movements you make with the dials won't be visible until you switch views
Jin_Yindao ( ) posted Sat, 21 December 2024 at 9:47 PM
Was just wishing that you did not have to use those controls as am so used to being able to pan by just pushing the third button on mouse and was hoping could set poser to operate the same when needing to pan the scene.  Have the cameras set to switch by pressing a number key.  When trying to correct the grouping after adding bones has proved to be difficult without the pan control.  My first go at trying to create a character from scratch.
Y-Phil ( ) posted Sun, 22 December 2024 at 9:33 AM
Mouse left click, don't release, press the space bar, move your mouse. Works on Win & Mac. I think that's pretty much like Ph0t0sh0p and almost like Gimp.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Richard60 ( ) posted Sun, 22 December 2024 at 11:19 AM
Slight update to what Y-Phil said is press Spacebar first then left click and move.  The other way around does not do anything.
Y-Phil ( ) posted Sun, 22 December 2024 at 1:39 PM
Oopsies, thank you Richard
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
nerd ( ) posted Sun, 22 December 2024 at 2:27 PM
Forum Moderator
Should mention too that [Alt]+Left Drag will rotate the camera. Scroll wheel will dolly in/out
ShaneNewville ( ) posted Fri, 31 January 2025 at 1:07 AM · edited Fri, 31 January 2025 at 1:15 AM
Jin_Yindao posted at 4:04 PM Sat, 21 December 2024 - #2990414
idk if animation is your thing, but in my experience here are a few tips on how to speed up your navigation in general:
- disabled middle mouse scroll in Preferences (its too easy to mess up the camera on accident when enabled, which is a big sad for animators)
- recommend sticking to Dolly Cam (its the best for film stuff as its the only cam with itself as the center point"
- disabled undo and animation in Properties for all cams except for Dolly Cam so you can use them as your work/eding views without getting unwanted keyframes and undo steps
- Rotate: Alt + Left Click
- Pan: Spacebar + Left Click
- Roll: Ctrl + Alt + Left Click
- Zoom: Ctrl + Spacebar
Note: You can switch Spacebar's function between Zoom and Pan by pressing T or Z to switch between the Editing Tools.
- Press Z for the Translate In/Out tool to Cause Spacebar to Zoom instead of Pan.
- Press T for the Translate Pull tool to cause Spacebar to Pan
(sometimes its quicker if you want to do it that way)
It helps to memorize the hotkeys to switch to your most used cameras:
Main Cam: Ctrl+M
Dolly Cam: Ctrl+/
Pose Cam: Ctrl+,
Left Cam: Ctrl+;
Right Cam: Ctrl+'
Face Cam: Ctrl+=
Right Hand Cam: Ctrl+[
Left Hand: Ctrl+]
(these and others are all shown in the Display Sub menu)
You can quickly select your camera to make it the active object by press 3 (above the letter keys, not on the NumPad)
Note: There is a life-long bug that exists where pressing 3 sometimes wont work, but if you quickly press 1 or 2, then 3, it usually works.
Also, if using Dolly Cam, I highly recommend adjusting the sensitivity for the Pan, Pitch and Roll dials (double click them) and set it to 0.1, because the default 1.0 is a bit extreme.
Would also recommend setting the Yon to maximum (i think its 10000, but if you just activate the value text field and hold 9 (till is shows like 9999999999999999) and hit enter it will automatically change it to the max value so you don't have to type it)
Also after making all of the above changes to cameras I would recommend pressing Ctrl+Alt+H on each Camera object in order to save that as the new default.  And save your preferences so you don't have to do this every time.
Being able to navigate fast in Poser is crucial.  Again, these are just preferences, but when we worked on RWBY and Red vs Blue in Poser we would set it up this way for the entire team so they could work muck quicker as animators.  It can save a lot of frustration.
_____________________________
My most recent Poser animation:
Previs Dummies 2
nerd ( ) posted Fri, 31 January 2025 at 3:19 PM
Forum Moderator
... An then get a Space Mouse for navigating the scene. Just know that once you start using a Space Mouse any app that doesn't support the it will seem antiquated and awkward.
Poser has supported these things since Poser 6 ... https://3dconnexion.com/us/spacemouse/
