Fri, Jan 31, 7:12 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Jan 31 3:19 pm)
Subject: dForce to Dynamics problem
mwafarmer ( ) posted Mon, 20 January 2025 at 3:55 PM Ā· edited Fri, 31 January 2025 at 9:40 AM
Hi, all
I have been working with dynamic clothing in Poser 13 for a while and find a simulation usually takes no more than a few minutes on my MacBook Air. Recently I decided to try my hand at converting a DAZ Studio dForce outfit to a Poser dynamic one. I had no problems exporting it as an OBJ, importing it into Poser and assigning materials, but when i go to run the simulation it sits at "Calculating dynamics ..." until I lose patience and kill it, usually after an hour or so.
Could this be an issue caused by the high polygon count? The outfit is a ski suit, so it covers most of the body and is pretty high-resolution. Is there a way around this?
Thanks in advance,
Mike
Sunfire ( ) posted Mon, 20 January 2025 at 4:28 PM
Try saving the suit at the base mesh resolution when you export the obj. Then it will have fewer polygons, and after simming you can increase the subdivision.
Assuming the suit uses subdivision to make it more high resolution.
Sunfire's Creations
mwafarmer ( ) posted Tue, 21 January 2025 at 2:06 AM
Thanks for the suggestion. I'll try that.
Mike
midinick ( ) posted Fri, 24 January 2025 at 10:32 AM
I have the same issues.. or impatience XD
Sometimes it helps if I look in DAZ to set Subdivision to 0, but not all chlothes seem to have this option. Sometimes, if I see the obj. (imported into Poser) has many many polygons I reduce the polygones via the menue (object - reduce polygones).. sometimes it workes good ^^ I usally reduce as much as I can without destroying the mesh. DAZ clothing are incredible high polygoned... I have no Idea how can DAZ handle this and Poser not :(
mwafarmer ( ) posted Fri, 24 January 2025 at 10:52 AM
Well, I was able to run out of memory and crash Poser, so I clearly need to do a bit more research there (and close a few programs)! šŸ˜€
Thanks for the pointers.
midinick ( ) posted Fri, 24 January 2025 at 5:08 PM
even my brand new computer can't handle some dForce clothing XD or I am very very impatience.. wich also can be XD I don't want to wait more than an hour just for 1 drape, and dynamic isn'tĀ  starting without draping XD
wfbp1w ( ) posted Fri, 24 January 2025 at 5:22 PM
if the Cloth item has subdivision you can set it in DAZ at the parameter Pane under ā€œgeneralā€ from ā€œHigh Resolutionā€ to ā€œBaseā€ then export it as Obj to Poser
midinick ( ) posted Fri, 24 January 2025 at 6:14 PM
wfbp1w posted at 5:22 PM Fri, 24 January 2025 - #4493161
could you make a screenshot please? :) I only use DAZ to export, I always search for this function on the right panel, but not all clothing seems to have this option, or I just didn't find it XD
mwafarmer ( ) posted Sat, 25 January 2025 at 2:18 AM
I see it. Thanks.
Mike
wfbp1w ( ) posted Sat, 25 January 2025 at 5:57 AM
There is also a very useful Studio Plugin called ā€œdecimatorā€, but itā€™s not cheap (I bought it on sale), with this plugin you can reduce the polys with a slider to your need. I think Blender has a similar function, but I donā€™t use blender.
midinick ( ) posted Sat, 25 January 2025 at 2:28 PM
Uh thank you for the screenshot, I will try it later again ^^
Poser can reduce polygones too :)
