Thu, Jan 30, 7:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 7:06 pm)
Subject: Clothing bunching when turning
RedPhantom ( ) posted Tue, 28 January 2025 at 10:51 PM · edited Thu, 30 January 2025 at 7:16 PM
Site Admin
When I load Lafemme 2 and some clothing things look good.
But when I rotate her hip 180 by the y or z axis, the clothing distorts.
This is the Y axis
and this is z
The x is OK. What causes this, and how do I fix it? It isn't Only Lafemme 2 that does this. It seems to be any figure I try. And it happens with both clothing made for the figure and converted stuff.
jadeite123 ( ) posted Wed, 29 January 2025 at 5:46 AM
I had a similar problem with a much earlier version of P13. I solved that by manually parenting the clothes to the figure body after conforming.
In addition, with the latest P13, that does not occur in my environment even without parenting.
VedaDalsette ( ) posted Wed, 29 January 2025 at 1:40 PM · edited Wed, 29 January 2025 at 1:40 PM
When they do that for me, I show hidden parameters, open the offsets and trans in the body parameter, and make them all zero. It usually works for me. Might not do it always.
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
RedPhantom ( ) posted Wed, 29 January 2025 at 5:52 PM
Site Admin
I do have the latest version installed. Parenting doesn't help. Changing the offsets made it worse.
DeeceyArt ( ) posted Wed, 29 January 2025 at 7:12 PM
Online Now!
That's really odd. I don't think I've ever seen that before.
Did you check all the conforming options in Properties, and did you try to copy the joint zones from the figure to the clothing in the Pose room?
RedPhantom ( ) posted Wed, 29 January 2025 at 8:42 PM
Site Admin
I've tried the conforming options, and I've copied the joint zones. Neither helped.
Rhia474 ( ) posted Wed, 29 January 2025 at 10:50 PM
Maybe if you know which clothes those are, you could contact the creator? That is very odd behavior from a clothing piece that technically was tested before selling it.
RedPhantom ( ) posted Thu, 30 January 2025 at 2:17 PM · edited Thu, 30 January 2025 at 2:17 PM
Site Admin
It's not that specific outfit or even that figure. That was just the one I was working with when I found the problem.
Here are Pauline, Miki 4, La Femme 2, Roxie, Vicky 4, La Femme, and Dawn (1) all showing the same problem. With each example, I tried to use something that came with the figure or at least something professionally made. I don't know what, if any, clothing came with Vicky, so I used the morphing fantasy dress.
And this only happens if I have the hip at 180 or -180 degrees. It doesn't happen if it's 170 or 181. Usually, I could just put it at 179 and call it good, but I was working on a pose where she was interacting with someone else, and even the slightest change could mess it up.
VedaDalsette ( ) posted Thu, 30 January 2025 at 4:51 PM · edited Thu, 30 January 2025 at 4:51 PM
I got the same result when I rotated Pauline's hip 180 and conformed her blouse. Everything was fine when I changed her hip rotation to something else. Also, why does Pauline X rotate when I just Y rotate her hips?
Old lady hobbyist.
DeeceyArt ( ) posted Thu, 30 January 2025 at 7:06 PM · edited Thu, 30 January 2025 at 7:15 PM
Online Now!
Yes I can duplicate this issue. Will file a bug.
EDIT:  The clothing does NOT bunch up if you rotate the BODY 180 or -180. Only the hip.
