Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
When they do that for me, I show hidden parameters, open the offsets and trans in the body parameter, and make them all zero. It usually works for me. Might not do it always.
Old lady hobbyist. All visual art or fiction is "playing with dolls."
VISIT MY ALBUMSFOR COMICS: https://www.renderosity.com/users/VedaDalsette/gallery/albums
You can also get to my comics from my book website: https://www.vdbooks.com.
I do have the latest version installed. Parenting doesn't help. Changing the offsets made it worse.
I've tried the conforming options, and I've copied the joint zones. Neither helped.
It's not that specific outfit or even that figure. That was just the one I was working with when I found the problem.
Here are Pauline, Miki 4, La Femme 2, Roxie, Vicky 4, La Femme, and Dawn (1) all showing the same problem. With each example, I tried to use something that came with the figure or at least something professionally made. I don't know what, if any, clothing came with Vicky, so I used the morphing fantasy dress.
And this only happens if I have the hip at 180 or -180 degrees. It doesn't happen if it's 170 or 181. Usually, I could just put it at 179 and call it good, but I was working on a pose where she was interacting with someone else, and even the slightest change could mess it up.
I got the same result when I rotated Pauline's hip 180 and conformed her blouse. Everything was fine when I changed her hip rotation to something else. Also, why does Pauline X rotate when I just Y rotate her hips?
On the way Pauline rotates. Think of it this way.
For X rotate, think of the AXIS (not the figure) going from right to left. The part will rotate along that axis. So being that X axis goes from left to right, the part or figure will rotate forward or backward.
For Y rotate, the axis runs vertically. So rotating along the Y axis will TURN the figure left to right.
For Z rotate, the axis runs front to back. So rotating along the Z axis will TILT the figure left to right (in other words, she'd lean leftward or rightward).
I believe figures and props all work that way.
I'm updating docs and will make a note to add this explanation.
When I load Lafemme 2 and some clothing things look good.
But when I rotate her hip 180 by the y or z axis, the clothing distorts.
This is the Y axis
and this is z
The x is OK. What causes this, and how do I fix it? It isn't Only Lafemme 2 that does this. It seems to be any figure I try. And it happens with both clothing made for the figure and converted stuff.
