This. It is 99 percent of this. Set to POSER Unimesh, try rendering again, let us know if it fixed it.Is it a question of making sure the skinning is Poser Unimesh?
(Figure/Skinning Method/Poser Unimesh)
For me at least, I get lines on the texture if it is set to Poser Traditional.
Is this a render or a preview? If it's a render, which render engine are you using?
Those are showing right at the edges of the texture. The face texture map ends right in front of the ears like that. And you say this only affects some textures. I think the texture map just isn't painted all the way to the edge. The solution would be to extend the edges of the face texture, like hborre said.
The lines we used to get from not picking unimesh were cleaner than this, I don't think it's that. (I think it's still a good idea to pick unimesh skinning, I just don't think that's the cause of this specific issue.)
well thank for all of the feedback peeps.
this is a full render pic and I use firefly . I looked and I don't see where gamma values is but their are no extra bump maps or other textures used with this skin. I use this for my comic so i need to be sure it looks right. I think I will try to extend the skin map areas on the texture.
On V4's and M4's, the white line is precisely on the limit between the face material ("1_SkinFace") and the ear+head ("2_SkinHHead").
I have seen such weird effect once, on a Vic4, near the nose flesh and I had to change the parameters to get around this.
From what I could understand, it's as if some parts are intersecting with one another. Maybe try giving another scattergroup id to one part, to see if that forces Poser to avoid that not desired intersection by setting the order in which the skin parts are computed.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Try turning off texture filtering, or setting to Crisp, on the various maps. It's a setting in the various image map nodes that comprise the textures. Sometimes there isn't sufficient "padding" (a bleed margin basically) at the edges of the textures in the UV tiles. You see this, in particular, happening with certain older textures. The texture filtering acts as an anti-aliasing on the textures, an unpleasant side effect being that the edges of the textures become blurry and not precise to the UV borders. If there is no "overspray", as it were, of the texture (the padding), artifacts such as this occur.
Poser added the Crisp setting to accomodate this, however setting it to None is generally the most reliable option.
Just a note: As far as Scattergroup ID (a poorly implemented, unreliable fix IMO) the artifacts that are brought about by SSS, which those setting attempt to deal with, are an entirely different thing than what is shown here. Likewise setting the figure to unimesh. The artifacts that show up on traditional skinning are similar in appearance but actually quite different, being shown at the borders of body part groups rathef than at uv seams. Still, it's never a bad course to test setting to Unimesh as a quick way to determine if it's the culprit, which it doesn't appear to be here.
this is probably an easy fix but I have this problem with a few skins for M4 and V4 .
as you can see along the side of the ear and where the two skin pieces meet around the body I have white lines showing. how can I stop this please?
