Sun, Feb 23, 10:49 AM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2025 Feb 22 11:15 am)
Subject: Jelly material
mini70 ( ) posted Sat, 08 February 2025 at 12:55 AM · edited Sun, 23 February 2025 at 10:09 AM
Jelly Dessert prop for Daz Studio
https://www.digi-dotz.com/index.php/props/jelly-desert-prop-for-daz-studio
You can open and save this daz props in poser 11 with DSONLoader script.
http://web.archive.org/web/20201101092548/http://d3d.sesseler.de/store/poserpython/dson_loader/DSONLoader.zip
Ref: https://www.renderosity.com/forums/threads/2930857/dson#msg4345106
How I can get more real jelly material?
I made this material by referring to Blender Tutorial JELLY Simulation/Animation!
mini70 ( ) posted Sat, 08 February 2025 at 8:09 AM · edited Sat, 08 February 2025 at 8:16 AM
another material
hborre ( ) posted Sat, 08 February 2025 at 8:42 AM
Quickly assessing your first material room screencap, I wouldn't use a second PrincipledBsdf for displacement. In Poser 11, displacement does not work quite well unless you subdivide the prop and use a math node to give you the right settings. Don't use emission as a translucent cheat in Superfly; it won't look correct. Subsurface scatter could give you a jelly-look but you will need to play with setting values to get it right.
mini70 ( ) posted Sat, 08 February 2025 at 10:14 AM
hborre posted at 8:42 AM Sat, 8 February 2025 - #4493562
Thank you so much!
I just used P11 for conversion the props. I'm currently using P13. I'll test jelly setting as you advise.
mini70 ( ) posted Sat, 08 February 2025 at 10:46 AM
What do you think?
ChromeStar ( ) posted Sat, 08 February 2025 at 12:14 PM
Personally, if you want a look like the original, I would reduce the Roughness quite a bit. Maybe even to 0-0.05. That will give it some surface shininess and gloss. The default 0.5 setting is a reasonable catch-all but lower values make things shiny and glossy, higher values make things matte.
mini70 ( ) posted Sun, 09 February 2025 at 3:18 AM · edited Sun, 09 February 2025 at 3:19 AM
ChromeStar posted at 12:14 PM Sat, 8 February 2025 - #4493569
Thank you so much! It looks much more real.
mini70 ( ) posted Sun, 09 February 2025 at 3:46 AM · edited Sun, 09 February 2025 at 3:46 AM
Materials for spoon & plate:  PRA - Physical Surface Shaders
https://www.renderosity.com/freestuff/items/82488/pra---physical-surface-shaders
mini70 ( ) posted Mon, 10 February 2025 at 4:11 AM · edited Mon, 10 February 2025 at 4:11 AM
--------- Final set -----------------
Jelly
Sauce & Cream
vG5n4JkK1X37k9JueDouDVDeOlNuDf5Xo7wL9FtB.png4vayTOikZUty4kq1y76VWduMy8uEi7es7AMpTzjR.png
hborre ( ) posted Mon, 10 February 2025 at 8:37 AM
That looks better.  I would correct two channels on the PrincipledBsdf node: uncheck the Legacy Scatter box and reduce the Specular value slightly, realistically, there is such a thing as 100% specularity.
mini70 ( ) posted Mon, 10 February 2025 at 10:29 AM
hborre posted at 8:37 AM Mon, 10 February 2025 - #4493591
How about?
hborre ( ) posted Mon, 10 February 2025 at 10:51 AM
The cream might be too reflective, but overall, it looks great.
midinick ( ) posted Tue, 11 February 2025 at 2:32 PM
this looks so cool, what if you make the cream also a jelly-material, only a bit dense?
ChromeStar ( ) posted Tue, 11 February 2025 at 5:45 PM
The other thing I might do, for a close-up, would be to increase the subdivision on the plate and spoon. That's in the object properties, not in the material (which looks fine to me). The edges aren't quite round currently and subdivision might fix that.
mini70 ( ) posted Tue, 11 February 2025 at 10:40 PM · edited Tue, 11 February 2025 at 10:40 PM
ChromeStar posted at 5:45 PM Tue, 11 February 2025 - #4493635
mini70 ( ) posted Wed, 12 February 2025 at 4:20 AM · edited Wed, 12 February 2025 at 4:25 AM
(increased the subdivision on the plate and spoon)tXnPtW9tGBTGDeeGl06n3ihYgm7n81kCw73vjYOr.png
