Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
2 solutions mwa. The easiest is the "Brow gone" dial. But that may be only on Victoria. I don't have Poser open right now so I'm not 100% sure. The other way is to set the material color to White, the Highlight color to Black and make sure that all the texture options have "No Texture" in them. They'll still be there but render invisible. Hope that helps. James
I don't know what to say about the lips. There is only one set and it should be textured by the head texture you're using. Make sure that they are not transmapped (unless you want them to dissappear). If you want to get rid of them. Just do the same as with the Upper Eyebrows. Make them White, highlight Black, and Trans min 0, trans max 100, falloff 0, and NO textures in ANY of the boxes below. If that's not what you mean, please explain further. James
heyas; the lips are actually part of the face mesh, you can't turn them invisible. (as you noticed!) if the texture you painted is on the face, but not the lips, make sure you have applied your texture to the lip material, and haven't left the default material on. also, make sure the lip base colour is set to white, and not some darker colour.
I'm doing a texture for michael but having a big problem with those big eyebrows. How do i get rid of them so that the ons i have on my texture will show, I have the same problem with the lips.
