Rather than creating hierarchy files I bring my models into Poser by editing an existing CR2 file. In your case open the skirt CR2 file in a text editor, search for "OBJ" there are two instances, change them to the new object file that you have correctly positioned in the Geometeries folder. Check that all body part names match (hip is not the same as Hip). Save the file with a new name (check that your text editor has not added "TXT" to the file extention) into the characters/whatever folder. Open Poser and in the characters/whatever section click on your new creation. Re save to get a library icon. Hope this helps. Regards PhilC
The problem your getting with the .phi is the names in it for the hip and abdomen do not match the group names in the .obj. Poser is very particular about case when it comes to it's files. You must have "Hip" in the .phi if you have "Hip" in the .obj. Use "hip" instead... and you'll get the same problem again. Though it is best to deal directly with the original .obj, you can use an exported one if you make sure ALL of the parameters are set to "0". One thing to keep in mind though is... in the cr2, Poser "welds" identical verticie. The result of your export may not match the original verticie count which would cause all morphs for that particular part to not work. I don't use Max, but I believe the name of that plugin for it to handle .obj's is HABWare or something like that. I remeber seeing something on Steve Cox's site about it. Steve's site can be found in resources ----------> -Rob
Plus, when Poser exports to obj or 3ds it does NOT call the parts the names in the orginal obj. It uses the names in the name field in the cr2. This is a real pain in the keester for us cr2 hackers. rbtwhiz is correct. The names for the objects in the object file MUST be exactly the same (case sensitive) as the names in the phi file.
Ok I exported the default Poser skirt as a .3ds file and modified it in 3D max 2.5 then exported it from there as an .obj File. Then I opened up notepad and made a Hierarchy file and put them both in the Poser4:Geometries:Poser4Clothes:Skirt Folder. so far so good "I think". Then I opened Poser 4 and Converted Hier file. During the conversion I got 2 error messages: No geometry to match node:Hip & same message for the Abdomen. It went ahead and had me name a new file and created a new .cr2 and .rsr but it is not visible in the window or on the side bar. but i can see all the info in the Hierarchy window. What might have gone wrong?
