Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
The problem appears to be because you have "apply texture to whole figure". In the material selector dialogue in poser there is a small check box that applies the texture to the entire model, if this is checked it will do precisely that. Normally this isn't a problem, but with any model that has been remade it can cause problems. This I think is what is happening to you. Try clicking on the apply texture to all to take the check mark out, then manually assign the correct textures to the eyes. That might work.
No, you shouldn't have to. Apply the texture as normal, then select the eyes in the drop down body parts list and turn OFF apply to entire figure, then manually apply the textures to the eyes. That way you save time because all the niggly parts like nails etc have the texture and you're just editing the eyes themselves. Leave the "apply to all" check off when you close the editor and it should retain the settings.
I'm creating a new figure, - have made texture with BROWN eyes. I'm working with the dials, - have added some face morphs and changing the size of the mouth etc. to get the person look like the person I'm copying. But the eyes turn shining white when I apply the skin texture. I've tried to apply separate eye textures in the hope of making the eyes the color I want them. But no cigar. They stay shining bright white. how do I get them right?? Thanks, Britt
