Sun, Jan 5, 12:55 PM CST
Subject: I need advice on lighting
skee ( ) posted Thu, 16 December 1999 at 8:17 AM · edited Sat, 03 August 2024 at 2:14 AM
the light on the face seems to much, should I change color or brightnessto make it blend more. objects: old lightwave figure: poser default female texture:vicki by Anton Kisiel background:created in bryce imported to poser
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
LoboUK ( ) posted Thu, 16 December 1999 at 9:13 AM
Lighting is one of those wonderful things that you can play with for hours getting just right. The only advice I can give you is to try reducing the light value slightly and seeing if that has the desired effect (or close to it). This, I think, is more a brightness issue than colour. And, BTW, that is one superb picture Paul
bloodsong ( ) posted Thu, 16 December 1999 at 9:15 AM
heya; i think it looks fine. the brightness of the face against the dark background makes your eye focus on that point, which is a major point of interest, so that's good. the colour is not washed out or too bright. the legs look a bit flat, you might try a fill light back there, or get rid of a fill light that is making the back edge of the near leg as bright as the front edge. (ie: make the front leg kinda fade into the darkness a bit more.) i guess that didn't help, huh? ;)
slb75 ( ) posted Thu, 16 December 1999 at 9:31 AM
I too like the amount of light on her face, but how come the reflection of the bottles is reflecting on everything but her? Maybe that's what's bugging you????
Ikyoto ( ) posted Thu, 16 December 1999 at 9:53 AM
If your using Poser's lights, I take it that it's a spot. Try reducing the brightness slightly and increasing the end angle.
skee ( ) posted Thu, 16 December 1999 at 10:10 AM
thanks ,I knew I could count on all of you for your expert help to help me see. This is the greatest place.
Ikyoto ( ) posted Thu, 16 December 1999 at 10:18 AM
heaven: all the fun of disney without the lines. Free meshes and high end rendering computers avalible on demand. commisary run by Dr.Legume.... gotta have something to make the you thankful of the good stuff.
ARADTech ( ) posted Thu, 16 December 1999 at 12:08 PM
I kinda like the pic the way it is...the light on her face makes it stand out.. ARADTech
SewerRat ( ) posted Fri, 17 December 1999 at 6:50 AM
off-topic...how did you do the reflection? I've never managed to make mirror-like surfaces in p4...am I doing something totally wrong? (obviously) SewerRat
skee ( ) posted Fri, 17 December 1999 at 7:48 AM
sewerat, the background picture was done in bryce,the figure was done in poser. I just imported the bryce file and then modeled the figure over it. The only way I have been able to give the apearance of reflections in poser is to make a texture map and add it to the object. It takes a lot of work to make it work right. BTW thanks for a question that I knew how to answer. skee
SewerRat ( ) posted Fri, 17 December 1999 at 7:56 AM
haha my pleasure =) I can ask more questions you know how to answer if you like grin nice picture =) SewerRat
skee ( ) posted Fri, 17 December 1999 at 10:24 AM
please do....if I can answer I will. I'm a newbe. skee
SewerRat ( ) posted Sat, 18 December 1999 at 3:04 AM
ummm questions...questions.... what colour or colours is a stereotypical zebra? the primary colours are Red, Blue and what else? How many arms does a normal human have? ummmmm.....ok, so I'm not good at thinking of questions. sue me. SewerRat
skee ( ) posted Sat, 18 December 1999 at 7:21 AM
the answers are...zebras are not in stereo ...primary colors are all the paint you can find ...and I have never met a normal human. skee
SewerRat ( ) posted Sat, 18 December 1999 at 10:30 PM
you got the last one right =) and there I was thinking it's a good trick question the first one wasn't meant to be a trick 'tho, just meant to get you off guard SewerRat
LocalHero ( ) posted Wed, 22 December 1999 at 2:46 PM
One question HOW THe HEEL DID YOU DO THAT BYRCE? All I could ever do was a mountain....I use Max, and I hate bryce, oh well, umm lighting I have a suggestion... Lighten up the backgraound and that will solve your problem. Nice work. Local
