Lighting is one of those wonderful things that you can play with for hours getting just right. The only advice I can give you is to try reducing the light value slightly and seeing if that has the desired effect (or close to it). This, I think, is more a brightness issue than colour. And, BTW, that is one superb picture Paul
heya; i think it looks fine. the brightness of the face against the dark background makes your eye focus on that point, which is a major point of interest, so that's good. the colour is not washed out or too bright. the legs look a bit flat, you might try a fill light back there, or get rid of a fill light that is making the back edge of the near leg as bright as the front edge. (ie: make the front leg kinda fade into the darkness a bit more.) i guess that didn't help, huh? ;)
sewerat, the background picture was done in bryce,the figure was done in poser. I just imported the bryce file and then modeled the figure over it. The only way I have been able to give the apearance of reflections in poser is to make a texture map and add it to the object. It takes a lot of work to make it work right. BTW thanks for a question that I knew how to answer. skee
NOTE: No trees were killed in the sending of this message, but a
large
number of electrons were terribly inconvenienced.
NOTE: No trees were killed in the sending of this message, but a large
