Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 7:29 pm)
Ok I put the stray hairs idea in for you, basically it is a series of layers using the "#1" brush in photoshop or a very small brush, put in a few hairs at a time varying the type of brush and layer, screen, luminostiy, burn, darken, lighten etc. then vary the lighting on the layer and the opacity until it starts to look the way you want. Another thing to think about is shadows...pick up the color of the dark shadows around where the hairs are and brush in shadows on the face on a separate layer and then work them in a little. Also don't forget that the erase tool, using the brushes is a good way to work in the detail you want...this took about 10 min to do...
Again, thanks for the wonderful ideas and suggestions. I see some things now that I've had a chance to sleep on it that I missed or that I'd like to have done differently, but I also see I have a ways to go yet. I'll take these suggestions and give it another shot and maybe have something to new (and better) to show for it in a few days. Thanks again. You're all rather encouraging!
Well don't forget to post your new images...hair is something that takes a little patience, but it is your ideas that make it work. The examples are just that, often it is just the touch of a shadow a stray hair here or there or a subtle application of the burn tool that changes the "look" of the image....
just try using the screen setting on either the brush or the layer or both, light wispy strokes or long light strokes work best...put in a few strokes here and there go to a new layer then go back and start adjusting the layers...it is not too hard just takes a few minutes and if you don't like it delete it....also hair will add to the energy and movement of the image.....
