Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
here is a link posted to applying transparencies in bryce in the bryce forums, using the same technique bump maps can be applied. You can go with a multi-channel setup, by putting the bump marble in the second channel, and loading your map in their, or put it in the first channel, and follw the procedure for applying a transmap, but apply the bump instead. Don;t forget to set a bump strength :} http://www.renderosity.com/messages.ez?Form.ShowMessage=68021
Texture set is DD's Angelique, IMHO the best low res set around. Super veratile humma humma humma. And her out fit is actually just her skin turned a differnt color with the material editor and I applied a single black line bump map to the chest for a zipper. I tried it in Bryce and it does work, altho it does look a bit different. But when you have lots of comic frames and wacky lights I hope the viewers don't notice. - Gazzy
