Tue, Jan 14, 6:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
Subject: How do i make a sketch render 2000*2000
dolly ( ) posted Wed, 16 January 2002 at 7:00 AM ยท edited Mon, 13 January 2025 at 1:47 PM
Hey all I have a commission to do and they want a sketch render style pic. So how can i make the sketch render the size of 2000 pixels by 2000 pixels any help appreciated cheers dolly
Staby ( ) posted Wed, 16 January 2002 at 8:12 AM
I suppose it is the same as in standard renders. In render options check "render in new window" and set the size you need. I hope this can help.
dolly ( ) posted Wed, 16 January 2002 at 8:30 AM
Thanks for the reply but i tried that and it renders the same size as working window cheers dolly
3-DArena ( ) posted Wed, 16 January 2002 at 10:07 AM
You know I've been trying to figure that out as well... you can't render it so what to do.....?
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
Staby ( ) posted Wed, 16 January 2002 at 10:29 AM
Sorry, I don't use the sketch designer a lot and I could only make a guess... I'm not at home and I don't have Poser and the manual in front of me so I can't verify myself, but can you render a sketch designer animation? If so maybe you can select single frame and set a different size of the window... I don't know if it will work, some time ago a member here suggested this trick to render a picture of only the wireframe of the scene, maybe it works in this case too?
The Doctor ( ) posted Wed, 16 January 2002 at 10:32 AM
No problem
  1. Go to the animation menu - animation setup
  2. Set frame size to 2000 x 2000
  3. Set Frame count to 1
    OK
  4. Go to animation menu - make movie
  5. Set sequence type to image files
  6. Set resolution to full
  7. Set quality to Current Sketch Settings
    OK
    result 2000 x 2000 sketch image file
The Doctor ( ) posted Wed, 16 January 2002 at 11:02 AM
Rendering at this size with the sketch renderer can take a very long time!
wyrwulf ( ) posted Wed, 16 January 2002 at 11:20 AM
Very good explaination, The Doctor. I have tried explaining the process a few times myself, but yours is very simple and clear. Have you tried making very large sketch images? I haven't experimented enough, but it seems that there is a size limit for the sketch animation image. The same method works for wireframe, cartoon, and any other display mode by setting the quality to Display Settings instead of Sketch Settings.
dolly ( ) posted Wed, 16 January 2002 at 11:20 AM
Thanks il try it cheers dolly
Don ( ) posted Wed, 16 January 2002 at 11:30 AM
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
It is quite easy. DL my short Tutorial at the provided link. I used to use the animation method, but now I set a new window at a larger size and resolution.
