Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
Sorry, I don't use the sketch designer a lot and I could only make a guess... I'm not at home and I don't have Poser and the manual in front of me so I can't verify myself, but can you render a sketch designer animation? If so maybe you can select single frame and set a different size of the window... I don't know if it will work, some time ago a member here suggested this trick to render a picture of only the wireframe of the scene, maybe it works in this case too?
Very good explaination, The Doctor. I have tried explaining the process a few times myself, but yours is very simple and clear. Have you tried making very large sketch images? I haven't experimented enough, but it seems that there is a size limit for the sketch animation image. The same method works for wireframe, cartoon, and any other display mode by setting the quality to Display Settings instead of Sketch Settings.
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
It is quite easy. DL my short Tutorial at the provided link. I used to use the animation method, but now I set a new window at a larger size and resolution.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hey all I have a commission to do and they want a sketch render style pic. So how can i make the sketch render the size of 2000 pixels by 2000 pixels any help appreciated cheers dolly
