Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
I would use two, three, or more spot lights... one pointing up through the lamp shade to cast the shade's shadow, one or more pointing down pointing at the lamp shade itself. Unless the room is smokey, the cone itself wouldn't be visible... but if you want the cone, you've already got the right idea, but use another spot (or two)to illuminate it from the camera angle, and set the transparency min higher than transparency max, this will make it more transparent at the edges and more 'smokey in the middle. You can also try several cones stacked inside one another for a better smokey effect. You might want to look at Nerd's fog prop for hazy effects.
Attached Link: http://www.renderosity.com/softgood.ez?ViewSoftgood=1687
If you have $5 to spare , check out this optionThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
![file_261018.jpg](https://live.cdn.renderosity.com/forum/threads/536623/file_261018.jpg)
My scene contains a floor lamp in a corner of a room. But I cant create the light effect. I put a blue cone in site of the light. In other 3D programs I can create this effect using a "volumetric light".But in Poser? Can help me ?Thanks
