Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
To all of you who responded to my original plea, Thanks! I have discovered what the reason is for the error message, how to correct it and the clue came from scifiguy (thanks). The reason for the message (which is the wrong error message) is when one downloads an object for Poser all the files have to be put into the approriate folders for the model to work properly. This varies by the way the author created it. I usually never read the accompanying "read me" files, but I did in one case and the author left instructions where to put the correct files. As I said, some are different and loading many into Poser folders can be very tedious. Now I read all the "read me" files. The problem with the Poser "memory" error message is that it is erroneous. The code should have been be written to reflect the true nature of the error. I have a friend who always tells me to "read the book", but guys aren't supposed to read instuctions; well, let this be a lesson to me. Thanks to all again.
Actually, the only misplaced files that will trigger the error message and abort the program are the 'obj' files. All the others (textures) can be found later by using the 'render' pull-down menu and finding the files. It helps to keep all the textures in one place, such as a file under Poser called 'jpgs' or something like that.
Hello, I am trying to load into Poser 4.1, a downloaded figure from a free sight, using WinME, 1.5G SDRam, 1.9G mghz, and I get an error message that says it cannot load because I am out of memory and I may have to allocate more memory to Poser. Does anyone have an idea how one would do this in Windows. The User guide only tells you how to do it in Mac.
