Sun, Nov 24, 8:31 PM CST
Subject: Ok, here's a mystery for modelers.
Ikyoto ( ) posted Thu, 30 December 1999 at 6:07 PM ยท edited Sun, 24 November 2024 at 6:11 PM
This is the problem I asked about a while back. The solustions offered were to re-load Poser and hope for the best, use the joint editor or a modeling app... Ok, I have tried re-loading. But the second I decode the P4WWG I get this twisted index finger crap. The joint editor is of no use. The mesh of the index1 section of ech hane is bent/twisted. I am learning RDS, but not fast enough to fix this. Anyone with an idea will win my gratitude... that and a really good recipe for sweet and sour cat... If needed I will send whatever is needed to who ever can fix this little problem. (Pan, I don't know how, but I am sure your cat did it!)
JeffH ( ) posted Thu, 30 December 1999 at 8:13 PM
Seems more like a render/redraw engine problem. I saw this happen to a figure just the other day as I was using the full tracking setting. The leg buckled just like that then cleared up.
shadownet ( ) posted Thu, 30 December 1999 at 10:44 PM
You might try experimental adjusting of the scaling dials for the hand and problem join(s). I had something similar to this occur when I first started out using Poser 3. I was able to go through and manual adjust the scaling on the hand and fingers to correct the problem than save the corrected model back to the library. No problems after that.
nnuu ( ) posted Fri, 31 December 1999 at 1:48 AM
i had something like that happen to me but it was on the forearm...cant really say what i did to cause it but i couldnt fix it...sooooo...i had to start over nnuu
Ikyoto ( ) posted Fri, 31 December 1999 at 8:02 AM
Thanks.. I guess I've been looking at it from a mesh problem rather than something simple... I have a habit of over thinking the plumbing. I'll let you all know in about an hour.
Ikyoto ( ) posted Fri, 31 December 1999 at 9:56 AM
Yup! That did it! Simple answers still work best. Thanks folks. now where's that damned cat......
