Thu, Jan 9, 9:36 PM CST
Subject: Not Y2K bug...but still weird
snakepit ( ) posted Sat, 01 January 2000 at 12:56 AM ยท edited Thu, 09 January 2025 at 9:33 PM
I adjusted all the facial morphs & saved the head as an OBJ. When I added it as a morph target, this happened (except for a slight position shift & added noise). Any idea what I did wrong? BTW - Happy New Year to everyone!
JVipond ( ) posted Sat, 01 January 2000 at 1:18 AM
I notice that one eyeball is next to the figure's ear. Your problem could be that since Poser considers the eyes to be separate from the head, your modified head does not include eyes.
Anthony Appleyard ( ) posted Sat, 01 January 2000 at 2:18 AM
If you used a part of an exported .OBJ as a morph target, this happens, as exported .OBJ's have a different scale & offset from the original geometry file. If you want to reconstruct a morph target from the geometry and the .CR2, you need special software.
Ghostofmacbeth ( ) posted Sat, 01 January 2000 at 8:58 AM
Normally this happens when the head that you are exporting is not the same size or in the same position as the one you would be importing it too .. make sure all the scaling is normal .. Normally what I do is load the new figure AND the one that I am exporting from into the scene to get them lined up perfectly . Good luck
snakepit ( ) posted Sat, 01 January 2000 at 7:36 PM
I appreciate the advice. Thanks all.
