Wed, Feb 12, 1:44 AM CST
Subject: Texture won't take... model turns black
brittmccary ( ) posted Sat, 02 February 2002 at 12:51 PM · edited Wed, 12 February 2025 at 1:39 AM
This has never happened to me before, and I'm stumped! I've made a model in Amapi, exported it as an .obj file, imported it to Poser, resized it, exported it out WITH groups checked. Opened it in UV mapper, - mapped it, - saved the model again and the texture map. No matter what I do, PARTS of the model turns black. Any known causes and solutions? Thanks! Britt
Kiera ( ) posted Sat, 02 February 2002 at 12:55 PM
Can you show a picture? =)
Impudicus Rex ( ) posted Sat, 02 February 2002 at 12:56 PM
Check to see if the object colour is set to balck. Make sure it's set to white. That's about all the help I can think of.
brittmccary ( ) posted Sat, 02 February 2002 at 1:13 PM
here it is...
brittmccary ( ) posted Sat, 02 February 2002 at 1:14 PM
and yes, the obj color is set to white. :)
Impudicus Rex ( ) posted Sat, 02 February 2002 at 1:20 PM
What does your texture map look like? Is it possible you have overlapping texture info? A black section on a texture map can be projected across more than one surface if the polygons on the texturemap overlap. Care to post the map?
Kiera ( ) posted Sat, 02 February 2002 at 1:23 PM
Yep, I am struggling with that right now for pd's character contest... I bet you have single black pixels stretching across polygons due to mapping. Try filling the entire map with something crazy, like bright pink, to see if you still get black sections. Very nice crown, btw. =)
brittmccary ( ) posted Sat, 02 February 2002 at 1:33 PM
Aha!! That is prolly it. Will try that later today.. and see what happens! Thanks! :) Britt
brittmccary ( ) posted Sat, 02 February 2002 at 5:39 PM
I think I've tried everything now. I've even modelled a single red rose, - imported it to Poser, - out to UV-mapper, - mapped it. Back to poser, - and the same thing happens. The rose is black. That might be interesting for some other project, but was not what I had in mind. I imported it to Bryce 5 to see how that would react, - and the rose takes Bryce textures with no problem. Hmm... I'm stumped. I think Xena uses PlantStudio... for the pot plants. They seem to take textures nicely. But is there a trick to the export/import of the obj format from Plant Studio?? Britt
Kiera ( ) posted Sat, 02 February 2002 at 5:44 PM
Very odd. I haven't used plant studio in Poser so I am not sure what is going on here. =/
Valandar ( ) posted Sat, 02 February 2002 at 5:45 PM
There also might be some pretty degenerate polygons. Try pressing "Insert" on your keyboard when you bring it into UVMapper, and it should tell you if any degenerate polygons are found, or not.
Remember, kids! Napalm is Nature's Toothpaste!
bloodsong ( ) posted Sat, 02 February 2002 at 6:04 PM
heyas; check the reflection colour, and try turning it to white, if it is black. degenerate facets end up black. also check that the polygons are not double-sided. poser flakes out on those, as well.
brittmccary ( ) posted Sat, 02 February 2002 at 6:23 PM
Hi! It's me again. lol How can I fix the polygons? It seems that that's the problem. I tried to set the reflection color to white, but no go. Is there a way that I can fix those polygons? And How do I "see" on the model that they're corrupt? Britt
brittmccary ( ) posted Sat, 02 February 2002 at 6:33 PM
Yup... pressing the isert button in UV mapper returned a message that 30 facet were corrupted, - and it asked me if I wanted it fixed. Of course I responded NO (jk).. We shall see! Maybe you guys have deserved a rose tonight! :)) Britt
brittmccary ( ) posted Sat, 02 February 2002 at 7:04 PM
Hmm... not sure I'm making progress. The stem and leaves are now green, - but the petals are still black... Arghh! Anything else I can do to fix this problem??? Anyone?
Kiera ( ) posted Sat, 02 February 2002 at 7:05 PM
Now I think you need to look into the two-sided polygon thing that Valandar mentioned.
sirkrite ( ) posted Sat, 02 February 2002 at 7:44 PM
Hmmm? This sounds famillar. I've run across the same problem with objects I made in Amorphium Pro. They worked fine in Bryce but not in Poser. I found to options to deal with it. #1 Does Amapi have a smoothing filter? In Amorphium, I found using it on my object before exporting it as an obj. file works, but it may round edges more then you want. You'll have to play with it to see how much you need to smooth it, to fix it. You can test it in Poser by applying any texture to it. Once you have it all fixed, then you can UV map it. #2 Export it as a DFX. file then import it into Poser, Use the grouping tool to creat a new UVed prop. Then export the new prop as an obj. file, then use UV mapper. Hope that helps. :D
brittmccary ( ) posted Sat, 02 February 2002 at 8:49 PM
kieraw - phew.... this has been a marathon! *lol* But I'll get there. (Not that I'm stubborn or anything *grin*) sirkrite; yup! that's what I did with the Daisy. I smoothened it, - then exported it, - just the petals to see if I could make it work. And I could. The flip side is that the little flower ended up with a VERY heavy polygon count! *lol* I'll have to see how little I can get away with in the smoothing department. But just so you guys know it, - there will be problems with flowers created in PlantStudio. ;) Phew. I seem to run into all kinds of weird problems! *lol* Who would have thunk that I'd use 2 days to create a rose (that still is black, btw. *lol*) Thank you guys! This forum is priceless! Britt
