Tue, Nov 12, 10:53 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Trouble with transparancy
JasenJ1 ( ) posted Tue, 05 February 2002 at 6:45 AM · edited Sun, 10 November 2024 at 8:26 AM
I started a little project the other day and quickly hit a snag. I'm trying to model a little stone box my wife has with a lattice work of holes in it. As you can see from the render, I used a texture map for the holes in the transparency channel. Unfortunately I forgot Carrara is a surface modeling program, not a solids modeling program.
Can anyone offer advice on a different way to tackle this object? I tried making the lattice portion a compound object in the spline modeler, but Carrara bogged down quickly with all those little holes - and I couldn't figure out how to wrap the shape into an oval.
Any advice will be appreciated.
  • Jasen
JasenJ1 ( ) posted Tue, 05 February 2002 at 6:47 AM
Here's the shader settings.
Also notice the weird stretching on the backside of the the model. I've tried numerous tiling settings, but that stretching just won't go away.
litst ( ) posted Tue, 05 February 2002 at 7:54 PM
Hi Jasen, Here's a little procedure i follow when i want to apply a T-map on an object : First, you got to choose the good mapping mode . I'd suggest to put a checker instead of you texture, this will help you to find the mapping mode you need . When you don't see any weird distortion on the checker, you're ready to add your texture . Then, load your texture and see if it maps well . If it doesn't, rotate it or flip it with its orientation buttons . I hope it helps . litst
JasenJ1 ( ) posted Tue, 05 February 2002 at 9:21 PM
The warping of the T-map is less important than the "double wall" effect in the render. I want holes in a thick wall, not holes in two thin sheets. I think my only option is to model the holes into the geometry of the object. But I'm at a loss for a good method of doing so. Maybe this is a job for Amapi? - Jasen.
