Hi genny, I just tried shrinking the lateral portions of the characters arm with the parameter dials, then the shirt to match, that helps. Confused by your suggestion of IVISIBLE ?, I cant find a command or process for that purpose apart from hiding the whole figure?,or is that what you are referring to? Thanks, Tommy.
Attached Link: http://www.renderosity.com/tutorial.ez
If you'd like to improve the lighting (make it look like the lamp is lit) go to the Renderosity Tutorials, & do a search on AZL - you'll find wonderul info in AZL's lighting tutorials.I think maybe his left arm is just a tad bit too much akimbo. Maybe bring his elbow in closer to his body, maybe it would improve the way his sleeve looks. I can't guarantee that will work, but it might be worth a try. His arm is sort of in an unnatural angle away from his body. It makes him look too tense. If he's reading a book, he should look a little more relaxed. And I agree, the dog is great! Wonderful image. Melanie
