Sun, Feb 2, 10:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: need help for create morph target with 3dsMax
romanichel ( ) posted Mon, 11 February 2002 at 6:43 AM · edited Sun, 02 February 2025 at 10:50 AM
Could you please help me for the use of export/import obj files from Poser to 3dsmax and 3dsmax to poser? I have the plugin from Habware, but when I export some parts of poser character in obj file format, then import and export from 3dsmax, then load morph target with the object files exported from 3dsmax, the parts are moving when I use the dial. Anyone could explain me please, or know tutorial?
MadYuri ( ) posted Mon, 11 February 2002 at 7:32 AM
Attached Link: http://www.renderosity.com/tutorial.ez?Sectionid=11
At the link are some tutorials.
MadYuri ( ) posted Mon, 11 February 2002 at 7:35 AM
PS: I don't have Max, but I think you moved the morph target in Max. That is a common mistake for other 3D programs also.
geep ( ) posted Mon, 11 February 2002 at 9:04 AM
If you change ANYTHING ...
o ... scale (even if you rescale) ......................... see line below
o ... position ................. (even if you think you've moved it back)
o ... rotation (x,y,or z) ............................. *see line above
the MT will NOT work properly.
You can ONLY change individual vertex positions.
Been there, done that!
cheers,
dr geep <---------------------------------------------------------(one who knows)
cheers,
dr geep ... :o]
edited 10/5/2019
romanichel ( ) posted Mon, 11 February 2002 at 9:42 AM
thanks for yours answer, but the problem for now, is for the import/export setting. without any change, only import and export,the object seems to move.....
geep ( ) posted Mon, 11 February 2002 at 9:52 AM
... export is as a "morph yarget?" Try doing it WITHOUT this box checked. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
romanichel ( ) posted Mon, 11 February 2002 at 10:01 AM
I tried with and without the morph target checked when export object from Poser, but I have always the same problem. it is some import and export settings in 3dsmax,and I tried some also!
mwa ( ) posted Mon, 11 February 2002 at 12:07 PM
When you import: check: Multiple Rotate model Texture cordinates OBJ smooth and put vertexscale to 1.0 When you export choose Object check: Rotate model Polygons Texture cordinates smooth group set Vertex scale to 1.0 and File to 8 Hope this helps and that you understud everything it's my notes from a tutorial a saw a couple of months ago Magnus
romanichel ( ) posted Mon, 11 February 2002 at 12:24 PM
Thanks Magnus. I just tried the settings you wrote, and it is much progress. The object only move up a little. I must try again!
mwa ( ) posted Mon, 11 February 2002 at 12:31 PM
Just let me know if you run in to some more problems?
romanichel ( ) posted Mon, 11 February 2002 at 12:34 PM
Thanks Magnus! I tried again, and that works well! Anyway, if you know some tips for make morph targete withs 3dsmax,that shall be welcome. Thanks to alls!
mwa ( ) posted Mon, 11 February 2002 at 12:40 PM
I could try to help you if you have more precis questions. But my best tip is to just play around with the model.(But don't move it!) Magnus
romanichel ( ) posted Mon, 11 February 2002 at 12:47 PM
I have no more precis questions for the moment! I just want to try to make some morphs target, and also create clothes with max, in the future. For the moment, I am just in the beginning of learn.
mwa ( ) posted Mon, 11 February 2002 at 12:55 PM
Me to!
