Tue, Dec 24, 12:19 PM CST
Subject: Help me please. One step forward, 2 steps back!
davo ( ) posted Wed, 05 January 2000 at 10:38 PM · edited Fri, 11 October 2024 at 9:07 PM
I've finally gotten around to trying my hand at texture templates. I'm using UV mapper, import an obj file, get things arranged, export, and this is what happens when I render in Poser4. When you see things on screen, all shows up well, when you sketch render all shows up well, however, when you render in normal mode, this happens, some faces show up black. This only happens when I export from UVmapper by Stephen Cox. When I import on obj from RDS or Rhino, things render ok. The problem is comming from UV mapper. If you can help me...pleeeeaaaasssseee. I'm begging you man (or woman), I'm begging you. Thanks, Davo
PhilC ( ) posted Wed, 05 January 2000 at 10:53 PM
Try this:- Open the exported BMP from UV Mapper into Adobe Photoshop. Click Image/Mode and change from Indexed to RGB Color. I then save in TIF format (BMP may work but its my preference) I had a problem with exports from UV Mapper and this cured it,Hope this will do similar for you. Regards PhilC
PhilC ( ) posted Wed, 05 January 2000 at 10:54 PM
PS err what is it? (grin)
davo ( ) posted Wed, 05 January 2000 at 11:16 PM
It's a naughty worm. What you see has NO texture maps applied. This is rendered straight after import, import obj, adjust camera, render. Badabing Badaboom, this is what you get. If you have any other suggestions, I am all ears. Thanks, davo
PhilC ( ) posted Wed, 05 January 2000 at 11:53 PM
OH I understand you now, I think the only way I can help is if I see the object file and run it through my system. If you think that would help then my email address is pcooke@mis.net. Regards PhilC
bergerac ( ) posted Thu, 06 January 2000 at 1:06 AM
I might not be able to help, but I may have the same problem:) What happens when you change the colour of the lights? Do the black patches change colour? I presume each segment of the worm consists of one group and one material only? Berge
Anthony Appleyard ( ) posted Thu, 06 January 2000 at 2:09 AM
In Poser, when setting the render color of a material (accesssed via the `Render' dropdown menu), for each material you must set the highlight color as well as the main color. Else, if you leave the highlight color as default black, then black highlights will result on the render.
davo ( ) posted Thu, 06 January 2000 at 2:17 AM
Nope, that didn't fix it, but thanks anyway. It works fine on any other import except from UVMAPPER. SIGH. I hope I can resolve this. Thank you, Davo
Traveler ( ) posted Thu, 06 January 2000 at 6:47 AM
I have this same problem, don't know how to fix it :( Maybe you should email steve about it. -Trav
Anthony Appleyard ( ) posted Thu, 06 January 2000 at 8:22 AM
Try this: Read the .OBJ file with a text editor. Look at all the vt lines, and check if any of the arguments in those lines are less than 0 or more than 1. Is there any chance that Davo could put that model's .OBJ file somewhere where I could download it and examine it?
davo ( ) posted Thu, 06 January 2000 at 9:21 AM
Thanks for the help, and Traveler, I did e-mail Steve and I'm gonna send him the file to dink with. This portion of the object is planer mapping mode (side view). The missing portions seem to be on the point that would be closest towared me on screen, so I'm thinking maybe if I offset the origin of the mapping it'll cover those facets. Goin to try now. Davo
Steve Cox ( ) posted Thu, 06 January 2000 at 9:39 AM
I've sent Davo a request for the model (before and after UVMapper) and when I have some more information, I'll let you all know. Sorry for the trouble =( Steve
PhilC ( ) posted Thu, 06 January 2000 at 9:44 AM
Dont sweat it Steve, I'm sure you will come up with the answer. I've been using your mapper for all my stuff, frankly I'd be lost without it :) Regards PhilC
Traveler ( ) posted Thu, 06 January 2000 at 10:43 AM
No need to appolgize Steve, we would all be lost without UV mapper. If you need more example meshes I can send some your way. -Trav
steveshanks ( ) posted Thu, 06 January 2000 at 1:18 PM
I get this at the point of booleans and to cure it I import back into cinema 4d and export remap it and they go away ...no idea why but it works LOL and its worth a try in rhino.........I think they are duff normals.....Posers fault I think I have loads of files that work fine in V3 but get this in 4.............Steve
Anthony Appleyard ( ) posted Fri, 07 January 2000 at 2:12 AM
If someone puts a copy of the faulty mesh where I can download it, I will have a quick look through it.
davo ( ) posted Fri, 07 January 2000 at 9:02 AM
The mesh has already been send to Steve Cox, thanks anyway though. Davo
Steve Cox ( ) posted Fri, 07 January 2000 at 4:22 PM
Okay, here's what I think was going on - When UVMapper exports a file, it originally wrote five digits to the right of the decimal place. When the numbers get small, this can cause a significant loss of precision. I've changed it so that it now uses eight digits to the right of the decimal place. It will lead to somewhat larger files, but does fix this problem (I may make this an export option in the future.) My best guess is that Poser didn't like some of the facets because they became non-planar with the loss of precision. Anyway, the new version 0.23h is available now at: http://home.pb.net/~stevecox Please let me know if you have any problems with this new build - Cheers! stevecox@optonline.net
PhilC ( ) posted Fri, 07 January 2000 at 4:32 PM
Way to go Steve, your work is much appreciated PhilC
davo ( ) posted Fri, 07 January 2000 at 8:30 PM
I just want to let you all know that Steve Cox fixed UVmapper and it works great!!!! No more blacked-out faces! Now I can work on wormy! Thank you Steve Cox. Davo
