I think it's the same thing like with the Lightwave .lwo situation: .LWO objects will load if they were made with a version of LightWave 5.6 or earlier. The Lightwave people changed the format as of version 6.0. Vue will import .LWO files created no later than LW 5.6. I think that's the case for True Space as well: The ones which aren't importing are likely newer versions of the .COB format. Strangely enough, 3D Exploration can read all these files just fine, and it's current version is younger than Vue 4....
I just gave some more import file types a try in Vue, & at this time it seems the only file that I can't import is .COB. All the rest imported / excepted a texture or material / & rendered fine. I suppose I can always convert the .COB file to another file type, then import it into Vue 4.05-02. . . ;^) Mark.
