Fri, Jan 10, 7:32 AM CST
Subject: How can I create a water splash effect?
trimegisto ( ) posted Tue, 11 January 2000 at 2:10 AM ยท edited Fri, 10 January 2025 at 7:13 AM
I want to create some water splash effects to surround something coming out of water. How can I do that? Can I also create a ripple effect? Any ideas? Thank you!
DM1234 ( ) posted Tue, 11 January 2000 at 11:04 AM
I've been trying for some time now to get water splashing from waves crashing against rocks for a Lighthouse scene without much luck. I can't remember where I saw it but I do recall seeing a tut for making ripples. I'm guessing, try making a gray scale image in a photo editor prog. of a circular pattern your looking for and import it into Bryce using it in the Terrain Editor? DM aka Nite Miner
Ghostofmacbeth ( ) posted Tue, 11 January 2000 at 12:24 PM
The ripples are fairly easy ... a terrain editor model with the greyscale circles like DM suggested ... It depends on what kind of splash effect you want but I think Codemans splurt would work well ... You can find it as a freebie at his site in the links below ... The R.S.O.B. site below has a good number of links to wave and water tutorials ... Hope that helped some
trimegisto ( ) posted Tue, 11 January 2000 at 4:54 PM
Thank you guys! I'll give it a try.
Eshal ( ) posted Tue, 11 January 2000 at 7:07 PM
Heya, There are also ripples on the BryceFreestuff page..just do a search for ripples and they should come up. When you have them you might have to play a bit it the materials editor to come up with a water that looks good on the terrain. Hope that helps Regards Eshal
I'm a genetically enhanced blonde...what's your excuse? ~Eshal~
DM1234 ( ) posted Thu, 13 January 2000 at 12:00 PM
What I'm trying to do for the Lighthouse scene I'm working on is have very large crashing waves that almost totally engulf the Lighthouse. I can get the basic shapes of these waves but the spray never quite comes out right. The scene is from a photo sequince I saw a couple of years ago on the web and haven't been able to find it sence. I don't know how they got the photos and survive. They had to be completely mad to be out in a helocopter in a raging storm to get the shoots. The shoots were so dramatic that I can still see them very well from memory. I've seen other people pull it off so I know it can be done. More of a case where my skills aren't quite as good as they need to be. DM aka Nite Miner
DM1234 ( ) posted Thu, 13 January 2000 at 12:05 PM
Shoot, I should have typed Shots :) DM aka Nite Miner
KenS ( ) posted Fri, 14 January 2000 at 1:17 PM
ripples should be easy by adding mutliple torus'one bigger than the other in a bullseye pattern. as for splash effects, Ive had increddible results using my particle mesh splatter pack objects, they are located on my site under 3D Models/Misc 1. http://www.chemicalstudios.com/ FT
trimegisto ( ) posted Sat, 15 January 2000 at 5:30 PM
Well, I did get good results with greyscale circles created and blurred in Photoshop.
