Wed, Nov 27, 5:48 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: CARRARA - Damaged objects after the boolean operation?
olli-e ( ) posted Mon, 18 February 2002 at 9:33 AM · edited Sat, 09 November 2024 at 11:03 PM
Hello! I have some problems with the boolean operations in CARRARA. Look my picture. I create a spline object and a cylinder. Then i will cut the cylinder off the spline object. The result is a damged object. Please help me. Who knows that problem? It dosent matter wich objects i took. E.g. cubics, cylinders..... The result is always a damaged object! Shit happens. I hope anyone can help me. Olli
HARBINGER-3D ( ) posted Mon, 18 February 2002 at 10:07 AM
I am by no means an expert on Booleans in Carrara - what I do know is that Booleans should be avoided at all costs - caus' they just don't work that well. I think the problem you display is because one object is a "solid" object and the other is just a curved plane. I've run into this problem a few times myself. The only solution I've found is to go into the vertex modeller - the holes are made - you just have to manually disconnect the verticies that are messed up.
olli-e ( ) posted Tue, 19 February 2002 at 12:16 AM
Thx for the very fast reply! But i have this problems also in "solid" objects. When i have e.g. one cubic and one cylinder and i combine they. Then is the surface of the cylinder deformed. I tried to debug this problem in the vertex modeler but i am not an expert. The object looks after the vertex most horrible! Its an similar problem in the cinema 4d? Or runs this expensive program better? Olli
Pistola ( ) posted Sat, 02 March 2002 at 3:10 PM
Wierd. Never had a prob. But I don't use Carrara for actual modeling, so that might just be me. In Ray Dream at least, if you tried a boolean in the main screen you took your chances, but in the vertex modeler booleans were fairly clean. Since this may or may not be the case in Carrara, I recommend you expand your suite- I believe TrueSpace 1 had a decent boolean engine, and it's free.
