Bryce renders better than Poser over all , but I often find that Poser will do better with the actual Poser models.. what I mean is that often textures and so on especially for characters, do not look as good in Bryce no matter what you do . Vially when I really need a character to be sharp and detailed I often create the scene in Bryce , every thing that will be behind the character and export the background image to poser .. then set up the poser character in Poser and use the Bryce image as a background and render .. make sure that you rendered the Bryce file to disk first so that you can get a really high res image to use. If you are going to have things in front of the character you will have to render those in Bryce .. then make a mask render and composite it all in a paint program .. not the perfect solution but it is the best I have found so far s.
I have been going the opposite way from Laurie, but it's the same idea. I have been using Poser renders on 2D faces in Bryce. It saves render time (by a ton!), eliminates fixing all the textures, and resolves most lighting issues provided you rendered your poser scene with your Bryce lighting in mind. Two pieces in my gallery use this technique:
Earth Mother (Most recent)
Clandestine Meeting (First attempt)
Yes I have done that as well Kieraw.. your images are wonderful examples .. I love that character in "Earth Mother" ..which way I go often depends on the image and the light set up in both programs ..(mind I favor being able to turn and do the final pose tweeks with a model that I can manipulate) .. it is great that there is a way no matter what... using a pic object also works great once in a while when I want to bring a tree or something I have painted into Bryce .. so many tricks to explore .. so little time g. Vially, I can not think of a way to do this in just the one program .. you can take your whole scene into Bryce but then you will loose your light set up ,, and wow you would have some work ahead of you getting all the textures in place.. wish we could have found a solution for you.
Attached Link: http://www.datamike.com/susu.htm
kieraw: If you are exporting posers as 2d faces to Bryce you can have them animated using my Bryce add-on: "Susanna Poser to Bryce 4/5". Susanna had previously this feature but it has now been expanded to have the AVI/BMP sequence played on as material (not just animated 2d face). Check out the anims "Movie time" and "Blob" at www.datamike.com/susu.htm [end of blatant commercial].This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Simple question, I know I can Import Poser files into Bryce, but what about the other way around. Is there ANY way to get a Bryce made object, into Poser? I can't seem to even find an Export for anything except terrains. Any help on this would be great. Thanks, Vially
