Thu, Jan 23, 4:18 PM CST
Subject: A problem with Stephanie??
MikeJ ( ) posted Sat, 09 March 2002 at 10:49 AM · edited Thu, 23 January 2025 at 4:14 PM
Anyone having problems with this new Stephanie and trans maps? Every single time I apply a trans map to the eyelashes, and then try to render, Poser crashes. Every time. And I've tried it about 7 times. Invariably, after reopening Poser for the 3rd time, the figure comes in with no body texture--just all white, even though the texture is (supposedly) there. Just your basic out-of-memory-time-to-reboot thing, although I know I'm not out of memory. Got plenty of that. But still Poser will not load the body texture again until after rebooting. Weird.
namja1955 ( ) posted Sat, 09 March 2002 at 10:59 AM
I had a problem with installing the Stephanie Texture. Got a bad CRC check on the texture .jpg. It just happened, I e-mailed DAZ. Haven't heard anything yet, maybe it's related to that.
pzrite ( ) posted Sat, 09 March 2002 at 11:02 AM
I've had no problems so far (using WindowsXP) I applied all the textures using the MAT poses (including the transparencies). The only thing weird I noticed so far is that the textures weren't applied on her nipples. I had to manually apply the textures.
MikeJ ( ) posted Sat, 09 March 2002 at 11:02 AM
I might add that this was just a Mike texture I bought, and not the Stephanie texture. It works fine with M and M2.
lalverson ( ) posted Sat, 09 March 2002 at 11:14 AM
I had poser crash after doing some mat poses for her texture and then hair. but I had done a few quick renders. but after a restart of poser and doing it again but not rendering and saving the lady and then rebooting and then doing an image (I tend to do these steps alot) I had no problems.
MadYuri ( ) posted Sat, 09 March 2002 at 11:15 AM
Nope, I don't have this problem (neither with a Mike or the Stephanie texture). shrug
JDexter ( ) posted Sat, 09 March 2002 at 11:20 AM
Not having a problem with trans either. Working with Mike textures though. (Not the hairy ones!)
thgeisel ( ) posted Sat, 09 March 2002 at 11:26 AM
No problems here till now!As you can see, shes feeling well
Marque ( ) posted Sat, 09 March 2002 at 11:28 AM
Also the Mike eyelashes don't work, so if you use a Mike texture replace the eyelash and trans for eyelashes with Stephi's and you will be fine. Marque
DocMatter ( ) posted Sat, 09 March 2002 at 11:34 AM
I also had a problem trying to install the hi-res textures. It tells me the StephBodyM2Hi.jpg isn;t installing correctly.
MikeJ ( ) posted Sat, 09 March 2002 at 11:38 AM
OK, thanks. It's still happening, but I guess it must just be something on my end, or with the particular texture I'm using. Great picture, thgeisel
Cris_Palomino ( ) posted Sat, 09 March 2002 at 12:58 PM
Mike, the UVs are different on all the transparency areas of Stephanie. The other changes took place on the chest and hip area for obvious reasons. Cris
MikeJ ( ) posted Sat, 09 March 2002 at 1:14 PM
Thanks Cris, that makes sense, although I've accidentally applied wrong materials before without Poser crashing when trying to render. And, I saw your picture, Angel of Sorrows of the 25th anniversary issue of Computer Graphics World, on page 43.... Lovely image. :)
Cris_Palomino ( ) posted Sat, 09 March 2002 at 1:26 PM
Thanks, Mike. :) Cris
Barbarellany ( ) posted Sat, 09 March 2002 at 4:31 PM
I am on a Mac with PP and bought the high rez textures. I loaded everything and thoug all looks ok when I applied the mat it changed the colors of materials, but didn't apply the texture itself. I had to manually do so. Anyone know why?
EricTorstenson ( ) posted Sat, 09 March 2002 at 7:08 PM
Hey Mike, your not the only one. I don't get a crash, just no activity. When I hit "Render" it never get's past the little dialog box telling me it is rendering. Leaving it sit for a long time doesn't help things in any way. I am using the hi-res textures, and tried it first with the full bump map (48Megs for the body) and then shrank the file down to half the size, with same results. I'm not sure what is going on. I thought I would let you know that you are not the only one. eric
Roy G ( ) posted Sun, 10 March 2002 at 3:09 AM
I was kind of hoping the Daz Texture Maps (standard res) would look nicer than this. OK what did I do wrong?
Roy G ( ) posted Sun, 10 March 2002 at 3:18 AM
Never mind. I was using the PP mats instead of the P4 Mats. Doh!
MadYuri ( ) posted Sun, 10 March 2002 at 3:18 AM
The Daz textures have 2 sorts of MAT files. One for Poser 4 (P4) and one for Pro Pack (PP). If you apply the PP MAT files in Poser 4 you get those black sooty look. Try the P4 MAT's.
