Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 3:14 pm)
I also have had this problem, I found out if you do a control -alt -delete to end task and then hit cancel, it will reopen that file and then let you bring in the texture you opened.... works for me. skee
NOTE: No trees were killed in the sending of this message, but a
large
number of electrons were terribly inconvenienced.
Thank you to everyone who told silly lil' me why my clothes files weren't working. You were right. And they work perfectly now. ;) But, it seems I went from one problem to the next. I have some textures and bump maps that are supposed to be used for certain clothing. Problem being, I can load the texture, but when I try to load the the bump map, or a transparency map, it won't do it. I can pick the bump map, and press the "load" button, and it looks like it's doing it, but when it's all done, it hasn't been loaded. It doesn't even give me a pop up warning, or anything. It just won't upload it. It also won't upload a second texture file if I want to. It's like it can only load one thing, and then it's done for the night. Now I know there's gotta be a reason for it, and I don't see what I can be doing wrong. If someone else has gone through this, can you please explain how to fix it? I'd really appreciate the help. -Kathleen
