Fri, Feb 14, 2:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Project help, please
KierPhelan ( ) posted Wed, 13 March 2002 at 10:21 PM · edited Tue, 11 February 2025 at 6:25 AM
Ok, I know how to use bump maps on my figures, but is there a way to create a bump map of a rendered (or pre-rendrered) scene? Whereas a figure, or group of figures, is rendered not based on lighting effects, but on positioning within the ground field. I'd prefer a smooth gradient from front (white) to back (black), but would settle for a staggered, contour map effect as well. The only alternative I've figgured is using a flat plain perpendicular to to the ground plain that Is incrementally moved backwards, exposing more of the figure. Each of these renders would then have to be overlayed in photoshop to create the desired effect. Is there a simpler way that I'm just missing? How About in a different rendering program? Any help would be appreciated. Thank You, KierPhelan Joel B. Talacko
geep ( ) posted Wed, 13 March 2002 at 10:28 PM
Have you tried using the "hither" parameter dial for the camera that you are using, and doing multiple renders to achieve your desired effect? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
PheonixRising ( ) posted Thu, 14 March 2002 at 4:06 AM
Is this a "Depth Cue" thing? You know, that feature in the pull-down menu we never use. I'm confused. Can you show us a pic?
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
geep ( ) posted Thu, 14 March 2002 at 8:01 AM
The "hither" of the camera is being increased from the upper left to the lower right. The "setup" (shown in the center) has no "hither." cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
