Mon, Feb 10, 12:23 PM CST
Subject: I need a 'round' sphere
LeBurns ( ) posted Fri, 22 March 2002 at 12:09 PM · edited Mon, 10 February 2025 at 11:50 AM
I been working on the pic below (it's part of a larger render) and was shocked to notice that the poser ball is not round! Since this is suppose to be a bubble I need to get rid of the corners. Does anyone know where I can find a ball with more polys so it's smoother around? Thanks
Penguinisto ( ) posted Fri, 22 March 2002 at 12:13 PM
sure - I can cook one up in less than a mintue. where d'ya want it e-mailed to? /P
Penguinisto ( ) posted Fri, 22 March 2002 at 12:15 PM
Also, do you want a 64-segment sphere (very round, but high-poly), 32-segment sphere, or 16? (I think the Poser ball is like 8 or something.) /P
LeBurns ( ) posted Fri, 22 March 2002 at 12:18 PM
Wow that would be great. The smoother the better as it is a large part of the pic. Send to gamerleburns@triad.rr.com Thanx! BTW, what are you using to make it?
Penguinisto ( ) posted Fri, 22 March 2002 at 12:23 PM
OpenFX... as soon as I can get all the normals to export, I'll have 'em cooked up. /P
Penguinisto ( ) posted Fri, 22 March 2002 at 12:32 PM
'k - check yer mail; I included two different styles, in both .obj and .3ds format. The smoothest of the two is the lat-long style ball, but boyohboy is it loaded with polys... /P
PJF ( ) posted Fri, 22 March 2002 at 12:57 PM
If you have Bryce, you could export that scene (as obj) from Poser, and then replace the Poser sphere with a Bryce example after import. Bryce spheres are absolutely perfectly round, no matter how close you get to them.
LeBurns ( ) posted Fri, 22 March 2002 at 2:31 PM
I loaded a sphere in Bryce 4, but it wouldn't give me the option to export the object. ?? I did find a nice sphere using Thorne's atmosphere tool, but I will certainly check out these others. Thank!
PJF ( ) posted Fri, 22 March 2002 at 2:39 PM
Unfortunately, you cant export any Bryce 'primitives' (box, sphere, etc). My suggestion was to export the items from Poser, replace the Poser ball with a Bryce sphere, and render the result in Bryce. Poser objs will import into Bryce4 just fine.
Lovely Lady ( ) posted Fri, 22 March 2002 at 3:32 PM
For a quick sphere that is not that heavy in polys you can do one in UV mapper. Under file menu its is new object and you can set the dimesions.
LeBurns ( ) posted Fri, 22 March 2002 at 4:12 PM
Wow thanks for all the help. I'm uploading the image I was working on now in the Poser gallery.
