Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 2:56 am)
Make sure you unzipped the .obj file to exactly the right place: :Runtime:Geometries:Poser4Clothes:New:Cheongsam.obj If you're on Windows, that will most likely be C:Program FilesCurious LabsPoser4RuntimeGeometriesPoser4ClothesNewCheongsam.obj It has to be exactly right, or Poser can't find it - it then tends to load something else instead, as you've seen. :-( If Cheongsam.obj is in the right place, look for a Cheongsam.rsr in the same directory. Delete it (with Poser shut down) and try again.
Okay I just loaded it and followed the instructions and when i go to load it ...... nothing can not open obj. file. When I open it manually I get the Causual P4 male which will fit on a P4 female but only with her permission :) Anyway anyone have a clue as to whats wrong.
