Community Center F.A.Q (Last Updated: 2025 Jan 22 10:24 am)
I already had a slight problem with it. If you installed the old patch, the new patch won't recognize it as a "valid file." It apparently only recognizes the "original" ones that shipped with P4. So what I did to make it work, was to install a second copy of poser 4 and then just moved the Poser4.exe,.rsr, and one other file, but I'd just suggest moving all the files from the root of the new Poser 4 directory, except the Runtimes folder, into the working copy you have on your system. It installed just fine. I haven't tried it yet, but it looks like they fixed quite a bit. I'll keep you all posted.
I've had exactly the same problem. Except one shoe to the genitals and the other goes somewhere on her back. However, the problem only seemed present when I read in a previously saved .pz3. When I posed a new character it seemed to work correctly...come to think of it I never saved and reopened the new figure. I wonder what would happen?
Get it now before'n it gets cold http://host-1.ghosteffects.com/poser/patch/patch.html
