Wed, Jan 8, 2:34 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2025 Jan 08 1:24 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: That damned patch is here!!!!!
Freakachu ( ) posted Wed, 19 January 2000 at 1:28 AM ยท edited Tue, 07 January 2025 at 12:14 AM
Get it now before'n it gets cold http://host-1.ghosteffects.com/poser/patch/patch.html
Freakachu ( ) posted Wed, 19 January 2000 at 1:30 AM
P.S. Go to Larry's site for the patch--his is newer than the one at MCs site
JeffH ( ) posted Wed, 19 January 2000 at 1:32 AM
The Final version will come after this one.
nicknoel ( ) posted Wed, 19 January 2000 at 2:47 AM
I already had a slight problem with it. If you installed the old patch, the new patch won't recognize it as a "valid file." It apparently only recognizes the "original" ones that shipped with P4. So what I did to make it work, was to install a second copy of poser 4 and then just moved the Poser4.exe,.rsr, and one other file, but I'd just suggest moving all the files from the root of the new Poser 4 directory, except the Runtimes folder, into the working copy you have on your system. It installed just fine. I haven't tried it yet, but it looks like they fixed quite a bit. I'll keep you all posted.
picnic ( ) posted Wed, 19 January 2000 at 9:23 AM
Well, I am going to wait until youall 'shake it out' (LOL)--and if Jeff is right, I'll just wait until the 'final' one. Diane
JeffH ( ) posted Wed, 19 January 2000 at 9:28 AM
You're supposed to do a fresh install of P4 from the CD, then apply the patch. -JH.
Anthony Appleyard ( ) posted Wed, 19 January 2000 at 9:32 AM
It would help if all patch installers did this:- (0) Copy Poser's (or whatever) directory tree to another place, just the directories, no files. (1) As it alters or overwrites each file, first copy the old file into the corresponding place in the copy of the new directory tree.
Kevin ( ) posted Thu, 20 January 2000 at 7:45 PM
try xcopy . "..poser 4" /d /s Worked for me. Assuming your old patched directory is "poser 4" and your new directory is inside the metacreations folder along with your patched directory. If you're using one of those funny colored curvey computers I have no idea how to fix it.
Anthony Appleyard ( ) posted Fri, 21 January 2000 at 2:35 AM
But I don't want to copy the whole of Poser including stuff that the patch doesn't alter: that would take up too much filestore space.
Kevin ( ) posted Fri, 21 January 2000 at 12:58 PM
That is what the /d does. Try xcopy /?. It has something like 20 odd command line options.
BAM ( ) posted Mon, 24 January 2000 at 9:28 AM
I've had exactly the same problem. Except one shoe to the genitals and the other goes somewhere on her back. However, the problem only seemed present when I read in a previously saved .pz3. When I posed a new character it seemed to work correctly...come to think of it I never saved and reopened the new figure. I wonder what would happen?
