Wed, Jan 22, 6:01 PM CST
Subject: WIP: "Seadragon"
Aldaron ( ) posted Sun, 07 April 2002 at 2:05 PM · edited Fri, 02 August 2024 at 10:35 PM
This is the original by Tim Hildebrandt, I had recreated this as a water-based painting while in high school.
Aldaron ( ) posted Sun, 07 April 2002 at 2:08 PM
So I thought I'd give it a try in Bryce. So far it's not bad, 212 objects with over 1 million polygons. The volume cloud eats up a LOT of render time. Any ideas of the best way to achieve the sea foam around the rocks and top of the wave?
Sihn ( ) posted Sun, 07 April 2002 at 5:03 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=133356&Start=1&Artist=Sihn&ByArtist=Yes
I created the airy splash at the bottom of a waterfall by creating a terrain, eroding it, and then hitting the spikes dot a few times. I then applied the polluted water default texture, made it a tad more transparent, duplicated the terrain and moved it slightly off center and applied a cloud texture. You have to experiment with the cloud textures because some look better close up than at a distance and vice versa. You can see how it turned out in this image.
