Tue, Feb 18, 4:50 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Saving Render Window to File
Jiia ( ) posted Mon, 15 April 2002 at 3:00 PM · edited Fri, 14 February 2025 at 4:44 AM
I'm trying to make a tedious task less tedious while rendering characters for a video game. What I do is place a character in the scene, set the Aux camera to the correct view, and load in the animations for the character. After this is all set up, I have to render each frame in the animation, rotate the figure Body by -45, then repeat until I go through all 8 directions. I've tried like hell to write this in python, but I'm having trouble. When I use the scene.SaveImage() method, it saves the scene view, and not the window that popped up to be rendered. Is there a way to save the rendered window instead? Also, is it possible to close that window after each save? Thanks for any help, I will really appreciate it. Jiia
markdc ( ) posted Tue, 16 April 2002 at 6:29 PM
No to both questions. Just render to the main window and save from there.
diegos ( ) posted Wed, 24 April 2002 at 2:56 PM
Markdc, do you know how to setup the main windows to a higher resolution? because if I render to the main window the max res I can set up is 1000x700 px.
markdc ( ) posted Wed, 24 April 2002 at 5:24 PM
Unfortunately you are limited to the max resolution of the main window. I've complained to CL about this. Maybe they'll fix this in Poser5.
diegos ( ) posted Wed, 24 April 2002 at 5:43 PM
One more thing to wait for P5! Many thanks.
