Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Attached Link: http://www.ambientlight.co.uk/downloads/textures/textures.htm
Try this site (for non-commercial use). I used their grass shaders (just jpegs) in these examples.Getting a jpg into the terrain editor isn't all that hard in RDS. Once you place a Terrain in the perspective window, the four elements: Earth window opens up. Click Edit, then above the area you normally paint in, click on the little floppy disk with an arrow pointing to the right. This allows you to import an image as height field. Default is BMP, but you can select JPG or a few other formats, too.
Attached Link: http://ashley3d.home.texas.net
Does anyone have a high-rez shader for seemless grass? I want to created a realistic looking building scene. As you can see, the building has alot of space all around it that needs to be filled with grass. Thanks, Ash
