Thu, Nov 28, 4:31 PM CST
Subject: BVH From text to .bvh
odeathoflife ( ) posted Wed, 15 May 2002 at 2:18 PM · edited Thu, 28 November 2024 at 4:25 PM
Hi I found a couple of sites (there is one just below this post with a link, as well as biovision) that has downloadable bvh files, but they are downloaded as txt rather than bvh, I have tried to rename the files, and also reopen and save as bvh's but they are still just txt names like climb.bvh.txt Anyone have any ideas Thanks
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Little_Dragon ( ) posted Wed, 15 May 2002 at 3:59 PM
Renaming the filename extension from within Windows Explorer should do the trick. BVH files are nothing but text, anyway; just open them in Wordpad and take a look. You don't actually need to change the filename extension; Poser will import them as-is, although they won't appear by default in the Open dialog, since it'll be looking for .bvh rather than .txt.
Basis3D ( ) posted Wed, 15 May 2002 at 4:23 PM
It's interesting to see that people on PCs are having a similar problem to us Mac folk regarding bvh files. On the Mac we're downloading bvh files that don't retain the text document attribute. They come in as "generic" documents which MUST then be converted to text documents in order for them to work at all in Poser. On the PC you're downloading text documents that won't automatically open in Poser without first changing their extension to ".bvh". Oh, the joys of computing!!! :-)
 Poser 2010 • Poser 8 • MacPro Desktop • Quad-Core Intel Xeon • 10 GB • Snow Leopard • Windows XP
elsja ( ) posted Wed, 15 May 2002 at 5:52 PM
In the explorer choose the folder option from the tools menu. Go to the tab view and uncheck the hide extensions from kwon file type. After that you can change txt to bvh without the explorer rename it to bvh.txt Be care after that you will be able to change anything to anything. Guy P.S: Explanation provides for win2000 for other that may be change.
odeathoflife ( ) posted Wed, 15 May 2002 at 6:41 PM
thanks all for your input
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
bikermouse ( ) posted Thu, 16 May 2002 at 2:22 AM
elsja: re "you will be able to change anything to anything." If it were only true - I could turn all this gold I got laying around back into lead. Message671424.jpg I will be watching for these bvh files.
elsja ( ) posted Thu, 16 May 2002 at 12:23 PM
bikermouse: Probably it will better I write : Be care after that you will be able to rename any file. The result may be a no running computer. Thanks Guy
