Sun, Feb 9, 2:27 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 1:04 pm)
Subject: Frustrated Poser Newbie
zymorfin ( ) posted Thu, 16 May 2002 at 9:25 AM · edited Sun, 09 February 2025 at 12:43 PM
Running: Poser 4.03/Windows xp Having just become the proud owner of Poser 4.03 I thought I'd try my first download from Renderosity Free Stuff. I decided to use a prop called 'Posable Crate' as my test piece. After following the instructions, [Say's he, crossing his fingers] I found my new prop in:- Libraries Palette/props/prop types/Posable Crate :o) When I tried to open it up I received a drop down message:- ERROR The file has a newer version number than expected. Poser will Attempt to load it anyway [ OK ] After pressing [OK ] an unrendered version of the Crate appears. Everything seems to work. ie. The lid opens and closes has required, but the prop is in skeleton form. I tried the Render Menu which again appears to work fine [Lovely old wood effect] But as soon as I touch any of the controls the crate reverts back to a skeleton again :o( Can anybody please tell me where I'm going wrong. NB. First post, hope it comes out Okay.....
TheWanderer ( ) posted Thu, 16 May 2002 at 9:41 AM
Hi Zymorphin what display type are u using, on your poser screen there should be a row of circles/spheres try clicking on these individually the last one in the row I hope (keeps fingures crossed) should let u display the crate with un rendered textures, the others may be able to supply more technical terms but i'm doing the at work from memory hope it works Dave
thgeisel ( ) posted Thu, 16 May 2002 at 9:42 AM
Thats all normal!! The error massage is because the prop was done in poser pro. Just ignore it. If you want to to have the rendered image, choose "render new window" in the rendermenue, set up the size of your image, render and save the rendered image. Now you can use it in any image edit program
Dagon ( ) posted Thu, 16 May 2002 at 9:47 AM
Display -->document style-->texture shaded
guslaw ( ) posted Thu, 16 May 2002 at 9:52 AM
You're doing nothing wrong. When you make any changes or adjustments you will have to render the picture again. It's kind of like a photographer taking pictures of a set-up In order to see how the setup looks he has to develop the film and print the picture (render the Poser image). When he changes the set-up, the original picture does not change. He has to develop the film and print a new picture to see the results of his changes. I hope this helps and welcome to the Poser addiction...
3ddave44 ( ) posted Thu, 16 May 2002 at 9:53 AM
yes, when you select controls again, you're working again so the workspace goes back into work mode. You could do as suggested here and use the texture shaded option but it's more memory intensive and rarely necessary for working. I only use it when I want to accurately position eyes - although I can also do that in a shaded mode by setting the pupil to black so I can see where the eye is going.
zymorfin ( ) posted Thu, 16 May 2002 at 9:55 AM
Are you guys great or are you guys greats...... I now got me an old crate to stuff into :o) Many, many thanks for your time and effort
hauksdottir ( ) posted Thu, 16 May 2002 at 4:32 PM
Welcome! Fair warning. Addiction always starts with something simple, like a crate. Next you'll want a mermaid or two. Some treasure. An octopus to guard the treasure. A skeletal ship in the background. Some sand for the foreground. ... Before you know it you'll have a 10 gigabyte runtime folder stuffed to the gills. Speaking of gills, you'll want a fish or three.... Besides being part of a sea wreck, that crate could be on the site of a dig (dinosaur bones or Etruscan artifacts?), or the hold of a spaceship (why do they always bring back eggs?). I'm only sort of kidding. Almost any item you see can be the starting point for an image, and the marketplace and freestuff sections in these forums are full of interesting bits. The hard part is stopping. Carolly
hogwarden ( ) posted Thu, 16 May 2002 at 4:42 PM
You reckon you're going to actually fit into that crate??? LOL! H:)
Allen9 ( ) posted Thu, 16 May 2002 at 4:57 PM
[[Before you know it you'll have a 10 gigabyte runtime folder stuffed to the gills.]] Yep, it's toooooo true! I'm doing a complete backup of all my poser stuff right now. 14 CD's full and another 8 or 10 to go. Addict?? Who, me?? You betcha!
smerc ( ) posted Thu, 16 May 2002 at 6:08 PM
As I say at work..."thats not a problem, its a feature" smerc
Allen9 ( ) posted Thu, 16 May 2002 at 7:28 PM
If that's your line at work, then you MUST work for microsoft. ANYTHING anyone else calls a problem, they call a feature.
hogwarden ( ) posted Fri, 17 May 2002 at 3:50 AM
LOL... Microsoft XP error message... __________________________________________________________ This program has experienced a new feature and will have to shut down. Do you wish to thank Microsoft for this new feature? __________________________________________________________ If you're getting bogged down by your bursting folders can I humbly recommend PBooost Library Manager?
ronknights ( ) posted Fri, 17 May 2002 at 8:05 AM
Hey, I will enthusiastically recommend PBooost. It's your Poser Salvation!!! Would you believe this wonderful program is only $20?! Wow!!!! ![Message671414.jpg](http://www.renderosity.com/photos/Message671414.jpg) Ron
