Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Attached Link: http://www.nerd3d.com
there's also a tutorial for EMC at Nerd3d, I'd advise getting both and read them at least twice before you do anything. Like they both say make backups before you even attempt to mess about with cr2 files, also think about getting the Tailor by codetwister, using this you can copy morph targets from the figure into the clothing then you can control them from anywhere with ERC/EMC. Thanks to both Robert & Charles for discovering it for us. RobAttached Link: http://www.nerd3d.com/Tutorial/SuperMorph.htm
here's the link straight to the tutorial but have a look at the other stuff on the site. RobAttached Link: http://www.zenwareonline.com
May I enter the thread and talk about my null morph use ? Rob ? I know something about ERC you do not talk in your tuts ! 8) But it's not me the discoverer it's Dan ! Coooooooooool ! A'kinIn the image above you can see a project I'm currently working on [here at DAZ] that utilizes "a few" different forms of ERC... Full Body Morphs, Partial Body Morphs, Full Body Joints, Partial Body Joints, Null Controlled Nulls, Full Body Scaling, Partial Body Scaling, Partial Body Tapering, Full Body Curve Zones, etc. etc. etc. :) Keep in mind that this is still an in progress project... it still needs tweaking.
A'kin, if it's what Dan [Wilmes] has recently contacted me about (cameras and lights), then I'm afraid I must tell you that it isn't new... I don't specifically address them because they fall along the same lines as scale, rotation, translation, ad nauseum, ad infinitum. As I mentioned to Dan in our recent exchange, basically any channel in a pz3 (being that all poser native parameter files are derived from it) can be influenced by ERC... what it boils down to is whether or not the slave channel will have trailing data following the ERC code (joint and blend zone establishment, smoothing zones for example). One exception to that generalization however, are morph channels (targetGeom)... they require the trailing data to be useful beyond being a null channel.
Many, many, things are possible via ERC...
-Rob
DAZ Productions
& RSOB
Attached Link: http://www.rbtwhiz.com/rbtwhiz_ERC.html
I finally figured out how to make a one-dial character morph that doesn't leave the eyes halfway up the head. It all has to do with ERC and master-slave morphs. Many thanks to Jaager for his advice on this topic. If anyone else is having trouble with this, here's an awesome tutorial that clearly explains how master-slave morphs work, AND how to make your own!
