Mon, Dec 23, 3:42 AM CST
Subject: depth of field help required please
etep ( ) posted Fri, 31 May 2002 at 4:42 AM · edited Mon, 23 December 2024 at 3:20 AM
hi, i am hoping some of the experts here can tell me how i can keep an object ( the main subject ) in my render sharp and in focus if i use depth of field as in a photo,
i have tried selecting the object (ie it is the only object with red wire frame), :>) help please!!
vasquez ( ) posted Fri, 31 May 2002 at 5:32 AM
Sorry but I can't clearly understand your problem. Did you used the DOF in the render options? And if so did you check the option to "current selection"?
vasquez ( ) posted Fri, 31 May 2002 at 5:34 AM
P.S. "to current selection" is the grey button under the values of the camera settings of the DOF
Erlik ( ) posted Fri, 31 May 2002 at 6:37 AM
And rendering has to be set to Premium.
-- erlik
Stephen Ray ( ) posted Fri, 31 May 2002 at 1:07 PM
Even when using the options for DOF to set the focal point, the object used, will still be slightly blurred ( even more so if it's a group ) I do a DOF render, then a regular render, than an object mask render. And use Photoshop to combined the two renders using the mask.
Stephen Ray
dan whiteside ( ) posted Fri, 31 May 2002 at 7:27 PM
Attached Link: http://www.bryceworks.com/tutorial/doftest.html
Size matters.Make all your objects rather large and do the "to current selection" and start with a lens radius of .01 and go up from there. The above URL shows some simple examples. HTH-Dan
