Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
The head can be removed from the base .obj and from the .cr2. I have an "in progress" version without the face, but I ended up getting the joint rotation orders wrong when I made the .PHI, so I haven't finished it.
I have tried to compensate by flattening the face as much as possible. You can reduce the Z Scale to zero and pose the face. A textmap may be needed to define the nose in 2D, but it might be easier than using a different texture image for each expression. That process does present problems with the eyes, however....
I am working on Cheese, but have hit a snag, in that the only visual reference material I have is that available online. How is Cheese's body shaped? Does he have the "swiss cheese bubbles" that are cartoon shorthand for cheese, or is he basically just a cube-like shape? Anyone? Legume, I have adjusted the head so it can be moved along the X, Y and Z axes. It can be hidden inside the body if you don't want it, or, as a separate body part, it can be made invisible. I have, however, been working on making it as 2D as possible, with some success. The characters should hopefully be available at 3DCC by week's end.
Praise "Bob"! :) Thanks, Doc.
