Well, Silver Relect is probably a Silver reflection map-- I'd try the standard one from Poser. I had the same spelling in either a Taruru or a Zippo download. Those jpgs look like textures, if uv means they have been uvmapped. have you tried them as textures? Only thing I can suggest is work with one thing at a time and if it works add to it. Just looking at the Window, I know I could use that. And I don't want to do schoolrooms. I'm constantly amazed at the singular high quality of the Japanese Posers and modelers who offer their products freely. Mascara was mentioned as a master of props-- he does very good guns-- there are a considerable number of Masters of textures and models in Japan. Batlabs has some of the most innovative clothing I've ever seen except for Miss Rubio's. I think we should be grateful they are an international treasure, I guess. Emily Thank you, Ron, for letting us know about the complexity and fine quality of this set. I've seen it several times but never considered it enough to look deeper.
silverRefl.pict refers to the silver reflection map included in Poser - pict is for Mac pict format. You can not read it probably because Windows cuts the pict to pic. In cases like this it can be good to have a monochrome texture map (whatever colour you can identify easily ) at hand and load this instead, then you can figure out where the missing map belongs. Karl
Attached Link: http://babelfish.altavista.com/
Hmmmm...spurred my interest Ron, so I tried to find this prop but was unsuccessful. There is an apartment prop but no classroom.I don't know if this will help but you could go to the link attached here and copy the readme txt into the box and ask that it be translated from Japanese to English.
HTH!
Irene
Attached Link: http://www.jet.ne.jp/~m-jacky/frame.htm
There is some great stuff there including School Uniforms for the P4 characters... and this Science Room which I downloaded again. Thanks for the link."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
I think he did change the classroom. I don't have any cameras in the version I recently downloaded. Now you got me going. I need to go through my old Poser CD's and find the original one I downloaded. Maybe the other stuff, including the cameras are there. I don't find that silverRefl.jpg in either Poser or Poser Pro. Thanks for the tips on the curtain, screen etc!!! Ron
Oh hell folks, shouldn't do this on too little sleep. Ron, ignore my bastardized image and instructions. I couldn't find the science room and went back to download it. Arghh! It's named classroom 2. I was combining both props. Tex's should still work fine. You have: Note: rotate the camera to see the front of the room. 1. The Classroom Basic Prop - room, blackboard, teacher's desk and clock. Use the wooden desk and chair with this. 2. Frontwall 2 - this is to make the science room. To use it, load the Classroom Basic prop then click on the blackboard (or select frontwall 1 from the prop list) and delete it. Click on and delete the teacher's desk also. Now load the prop named frontwall 2. This loads in a different blackboard, a different teacher's desk and the projection screen. Use the "Rika" desk (science lab table) prop with this layout. The new blackboard covers half the clock so you'll have to move it or just delete it. All simple when you look at what you're doing, though I maintain he could have named the files a little better :-) My versions are (only English in the readme's): ClassroomProp = Rev1.0.0.1b - 2001.9.16 ClassroomProp2 = Rev1.0.0.0a - 2001.9.23 BTW there's not actually a camera file included. What I really meant is that the prop loads with the camera inside the room by default. Unlike some I've seen where I have to pan and dolly for an hour to get inside and get my bearings. Now go forth and render schoolgirls. Decided not to do the corridor pic - not much to look at and it takes forever to upload for a poor 56ker.
Wow, now I'd stay after school late for that one. I vaguely remember someone else did a rather "naughty" picture of a teacher standing, "partially clothed," on top of her desk.. something like that. Boy that one stayed in my memory, and I was tempted to create a similar render as my first. I used some restraint!
Ron, you should be able to take the silver reflect.jpg I sent you and place it in the reflection maps folder. At least it's asking for a jpg now, that's progress. You can scale up the Basic classroom prop but unfortunately, the scale on the wall, desk, etc. is locked so scaling isn't an option unless you edited the cr2 to unlock the dials on the other parts. Since I know you don't like to mess with that, I'd suggest just scaling down the figures. I don't know what to tell you about the clothes though. I think I saw a thread about conforming clothes and scaled figures but I'm not sure. Also try using Vicky2P4 she has Posette's body and is just a tad taller - closer in height than Vicky. If the kids look a bit big in comparison to her, hey she's just short, like Dr. Ruth :-). Perhaps someone can contact Taruru and get his permission to scale the prop to something more appropriate for Miss Crabtree.
Ron I don't know if the silverefl.pict IS the right file but I downloaded the classroom, without renaming or otherwise altering the silver file referenced it 8? times and it worked. the problem you are having is that the pr2? file references the texture 8 or 9 times and asks where the silver file is each time. Bikermouse, having some degree of patience, found this out by looking at the main prop file and counting the number of references, then going through the procedure the required 8-9 times. - " patience my a__!! I want to kill sumpin'"
Yes, the silver reflection map is used on a pipe and various other places. I just don't know where people are getting a reference to a pict file. My files are dated 9/16/2001 (classroom.zip) and 9/23/2001 (classroom2.zip) and they use a jpg reflection map. That, I already had in my ref maps folder. Now whether it came with Poser or somewhere else, I don't know. Various people have included so many variations on those files in downloads, I have at least 3 variously named silvers and ditto for gold, plus 3 or 4 chromes. As long as you have something close, a quick run with a search and replace utility should get the props using whatever you have. BTW, I found out how to scale the desk, etc. While scanning the cr2, I saw the word "Lock" and a light came on. Duh, select the object then go to the menu object and uncheck lock actor.
